Question about HP Pavilion dv6000z Notebook
Usb problem with vista
Unable to use flash drive with a newly bought laptop, says hardware id is missing.
    Genius:
  • 3,587 Answers
Gotta get the latest vista friendly drivers from the flash usb site..whoever that is.
Posted on Mar 09, 2008
I found this in a forum and might help you the way it helped me.
His name is Dragor
Step 1: Hit Win+f { Hold Windows Key and simultaneously press f} and click on Advanced Search.
Step 2: In "Locations" Select the drive where Vista is installed and remember to tick mark the "Include non-indexed, hidden, and system files (might be slow" check box.
Step 3: In the highlighted search box, type "volume*.*" [Obviously, without the quotes] and wait for the search to get completed.
Step 4: Once u have located the volume.inf file, copy it and paste it in "C:\Windows\Inf" folder. I've used a hack to put Copy to in right click of every file.
Step 5: Now close everything and come back to desktop. Click on start and type cmd in the Start search box BUT do not click on it or press enter. Instead, right click it and select run as administrator. The Window of Command prompt MUST read "Administrator: Command Prompt".
Step 6: Now type:
set devmgr_show_nonpresent_devices=1
and press enter. Now in that same window type:
devmgmt.msc and press enter. Device manager should now open. Now click on View menu and click on show hidden devices menu.
Step 7: Expand the Disk Drives entry and u should find ur USB flash disk in disabled state. right click it and uninstall it. After
uninstalling, connect your USB flash disk and voila! The system finds the drivers!
Posted on Mar 11, 2008
Hardware id missing
I got that error when my IDE to USB cable went bad. Although it could also be bad/corrupt drivers. Can you put the drive on an IDE cable to check it inside a computer without the USB?
Feb 24, 2014 | Toshiba MK6026GAX 60 GB Hard Drive
My toshiba cannot boot through USB. it dispalays "windows missing" yet the flash disk has got a windows xp setup
Your flash drive only has the setup program not the actual OS as it would be on your hard drive.
The fact that it won't boot through your USB is because there is no OS on your laptop with the required drivers for your USB and other hardware, for that.
You need to have OS installed on your hard drive to be able to run all the peripheral hardware, else nothing happens.
Please install the apropriate Operating System (OS) on your hard drive, and voila!!! magic happens after that.
Cheers, Peter
Feb 21, 2013 | Toshiba Satellite A135-S4477 Laptop AC...
My pen drive unable to show my data on it & aiso not detect in any pc or laptops.What can i do?
If the flash drive is not detected, it means there is damage to hardware.
Flassh drive hardware malfunction, there are two types
1. Cracked solder.
Solution: Open the flash drive casings, heat the tin solder.
2. Resistor (R) broken
Solution: Open the casing flash drive, flash drive instead of resistors.
Hopefully this information helps
Nov 09, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pny 2gb not recognized by windows vista
Try connecting it some other computers.
If it does not work at all, spend $8 to replace it.
If it does work, then it's either the "hardware" on your computer, or the Vista "software" (wrong/missing USB device-drivers).
Apr 20, 2011 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
My usb doesn't detected by any computers since I plug it to one computer. The red light does'nt appear anymore. My father bought it newly last week, I really wonder whats happening, I didn't even drop it...
USB what???? I assume a memory stick.
Can any PC ID the stick in "My computer" if not the stick is faulty assuming that NO PC's can ID it.
If you can see it in the above then double click on the drive letter for it and access files.
NB = Some memory sticks have a software disk to arrange security....ifyous has this disk then install it.
Jan 07, 2010 | Electronics - Others
None of my external hard drives or flash drives recognized by Vista
Ok Go into your hardware device manager and uninstall your Universal Serial Bus Controllers and if there is mass storage device also uninstall it. Click on action -> scan for hardware changes, then it should automatically install the drivers back now it should detect.
May 03, 2008 | Maxtor Hard Drive
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 4GB cruzer micro usb flash hard drive
try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Vista has not been out long enough for any company to state that there product is compatible. I would check there website to see if they have updated drivers that will make the sandisk usb drive compatible. This may fix the problem!
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
HP Pavilion dv6000z Notebook Logo
161 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
