Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
Adjust not working
I have a spf-40 and all of the functions work except the adjust button when I push it in nothing happens. I have removed the back and can see that the connection is being made by the metal prong that is being pushed by the button but still no adjust. Please help.
I had this problem with mine after a battery replacement. If you open your watch, and look behind the offending button, you'll notice there is a small arm that should fit behind the button. the jeweler that destroyed my O-ring during a battery replacement also failed to line these arms up on one side of the unit. i had to find a REALLY small screw driver and finagle the arm back under the button... Now it's working perfectly... except the whole not waterproof any more part....
Hope this helps.
Posted on Jun 21, 2008
I had this problem as well and the whole internal module required replacing.
Cheers
Brett
Posted on Apr 27, 2008
I have replace the batteries and after assembled the mode and adjust buttons are not functional.
I've had the same problem with another Casio watch and in my case I didn't place the inner parts of the watch exactly right. This must be done very precisely, otherwise one or more button functions don't work. Maybe it is worth a try to check the alignment of the inner parts of the watch.
Mar 15, 2015 | Casio Watch Sea Pathfinder Spf-60-1aver...
My wife has a Nike Alpha Project watch with new battery. We cannot set the time. I press "Mode" and nothing happens. I hold it down and nothing happens. Perhaps the buttons do not work? Shawn
Maybe the button is not pushing the internal button properly. Undo the back and remove the watch unit from it's case and then see if it works when you press the internal button.
Aug 02, 2010 | Watches
My michele watch chronograph is stuck
Have a watchmaker fix it...there isn't anything you can do.
Mar 24, 2009 | Michele CSX Diamond watch
CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
Feb 28, 2009 | Oakley GMT OAK0531 Wrist Watch
Timesetting on Athletic Works wristwatch
I have a AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
Feb 17, 2009 | Oakley GMT OAK0531 Wrist Watch
Problem with casio sea-pathfinder watch
For all Casio watches go to www.casio.com select "Support" then "Manuals" then "Watches".
You will then be able to enter the 4 digit number in the square box to get the manual for your watch or module inside is actually what the instructions refer to.
The problem of changing functions automatically is called "Auto Display" and can be stopped and started in Sea-Pathfinder SPF-40 (modue 2273) by pressing the bottom left button for 3 seconds.
Nov 13, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Casio Illuminator w-94h
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
Nov 19, 2007 | Casio PRG-40T-7 Pathfinder
Not again . . .
Pushing all the buttons at the same time you resets the digital functions. You'll have to reset the time and date, but it will all work again. I don't know why the watch freezes up, but pushing all the buttons at least resets it. I like my watch and this quirk is an annoyance, but it's livable after finding this solution.
Jul 10, 2007 | Timex Expedition® Outdoor Casual...
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
269 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
