Washing machine drain problem
Samsung top loading wm model SW70A1IG/XTL.
Sequence of failure:
power on-fuzzy selection -water level high/medium/low selection anything -cold water selection -timer shows 77 min.-start button on - tiomer shows 74 min.(whereas no previous water level inside) - inlet valve not opening - drain valve opens with IE error message after few seconds - without draining all water drain valve closes after one second.
What I tried:
cleaned pressure chamber, pressure tube and checked pressure switch with a continuity tester. Pressure switch tested same continuity result for no pressure and for applying pressure using mouth blow in the tube. May be testing was not perfect.
Again I tried for same setting - this time water inlet valve opens - water comes in - but for if level selection is low - water becomes full then stops inlet valve-water incoming stops - now agitator revolves only one round - then drain valve opens - drain valve closes shortly without draining all water - IE message displays.
I am trying - trying - trying : please solve
(please note in any case water tap is opened, no air lock in water hose, inlet filter clean all checked)
  • 1 more comment
  • dkray Mar 09, 2008
    Thank you sir. Model no. is confirmed as I have written. Made in Korea. Is it possible to check any fault in PCB using Multimeter or a continuity tester. Today after posting this problem, I went to market and got a continuity tester. I checked the pressure switch three point pairs. The result for continuity and infinity for a particular pair was same for pressure and no pressure in the pressure tubing.
    I have no service manual for this item.
    Still having problem. Always the drain valve opening first for few seconds. (without taking water after pressing start button). Then drain valve stops with IE message. Model no. SW70A1IG/XTL Samsung Made in Korea.
  • dkray Mar 11, 2008
    Can you please suggest me how timer can be checked. My washing machine has a digital display timer (square cube type with top side digital display). Changing major parts and to get a new one may be an easy solution, but before doing that I want to check the timer. I have little bit idea about electronics, I have a multimeter and a continuity tester. I want to use them, mainly this will add some more experience to me before accepting that easy solution. ( I wanted to diagnose the fault actually before changing any parts and I was expecting some fault diagnosis technique from the experts of FIXYA team.)
    Can you also tell please what is approximate cost range of a new PCB of washing machine.
    Master:
  • 377 Answers
Suggest this site here.
Posted on Mar 09, 2008
    Genius:
  • 3,587 Answers
You know, it sounds not like a mechanical issue. Sounds like your control circuitry is off kilter..
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    this is a clear example of the timer/control system missing the signals. I believe you'll find that the core electronics and chips are skewed. Only way to resolve this will be to replace that whole control board. Not too hard, and it beats blowing into a hose, too.
    you got a service manual for this item?
  • Patrick Michaels
    can you confirm that model number please..not finding that item as listed among resources
  • Patrick Michaels
    Only when it's necessary, microdude...only when it's necessary
  • Patrick Michaels
    ok...well..then you probably have a bad board...continuity is useless for an integrated circuit like the one that controls your washing machine
    I did not find that model number in Samsung US website, perhaps you can find it through their Japanese site.
    thanks for using Fixya..got to head for the sack now.
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    big issue with multimeter and the panel control is that it's a true state flow chart approach. Not a resistance approach..it either works or it doesn't
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
Here's a few instruction's How to Diagnose Washing Machine Problems
Step 1:
If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut off temporarily. Let it cool for 30 minutes, and if it still won't start, call a professional.
Step 2:
If the motor transmission failed or the drive belt has broken, these need the assistance of a professional.
Step 3:
If the washer won't drain, clean out the drain hose and straighten any kinks. If the drain hose fits too tightly in the standpipe, adjust it to allow for a minimum of 1.25 inches for airflow so water can drain.
Step 4:
If the washer won't fill or fills slowly, turn the faucet handles counterclockwise as far as possible. This is usually the result of partially open faucets.
Step 5:
Call a profession if the washer overfills. This means the water-inlet valve or switch is defective.
Kindly regards,
-micromaster
micro & yakman unltd.
  • 6 more comments
  • micromaster
    micromaster Mar 09, 2008
    How to Fix a Washing Machine That Fills Slowly
    Things You’ll Need:
    • Old Toothbrush
    • Small Bucket
    • Adjustable Pliers
    • Small Flathead Screwdriver
    INSTRUCTIONS:
    Step 1:
    Turn off the water faucets that feed the machine.
    Step 2:
    Unplug the washer and pull it far enough away from the wall that you can get behind it to work.
    Step 3:
    Remove each water-supply hose, using adjustable pliers. Start at the end that connects to the inlet valve on the back of the washer (see A). Hold a small bucket under each hose as you remove it to collect any water that's left in the hose. Then remove each hose where it connects to a faucet.
    Step 4:
    Locate the screens. Most washers have intake screens in the hose ports on the back of the machine. But your machine also may have aftermarket screens. They'll be inside the hose couplings, in the ends that attach to the faucets.
    Step 5:
    Gently pry out the screens using a small flathead screwdriver (see B). Take care not to dent them.
    Step 6:
    Clean the screens, using an old toothbrush.
    Step 7:
    Reinstall the screens, using the tip of your screwdriver to push them firmly into place.
    Step 8:
    Reinstall the hoses and tighten the couplings securely.
    Step 9:
    Turn on the water to check for leaks, then plug in the machine and push it back into position.
    Kindly regards,
    -micromaster
    Please rate.. thanks.
  • micromaster
    ei buddy >>IBG, good eve to you.
    I hope you never post the My Way Video here...LOL..
  • micromaster
    yah...& your the only one here that make's micro smile...
  • micromaster
    A washing machine that won't drain can be as simple as a small clog or it might be time to call the maytag repair man. Follow these trouble shooting steps to possibly save some dough.
    Things You’ll Need:
    • Basic tool kit
    • Flashlight
    • Bucket
    • Rags
    Step 1:
    Check hose for kinks. Straighten hose best as possible or replace. If hose is looping gravity may be the problem. Try cutting off excess.
    Step 2:
    Test lid switch for "click". If you don't hear this "click" you may try replacing it by ordering a new one from the manufacturer and following installation instructions. Fairly easy job for a do-it-yourselfer.
    Step 3:
    Check belts to see if they are loose or broken. Most washers have removable panels that let you get to the pumps, motors and belts. Belts can also be done by a do-it-yourselfer but can get tricky, you may want to seek a friend who has some belt experience.
    Step 4:
    Check hose that connects tub and pump. Remove hose with bucket and rags close by, check for obstructions.
    Step 5:
    Check pump with voltmeter could be an actuator(a value that controls what flow). Not a good idea to play with water and electricity find someone who knows what they are doing.
    Step 6:
    Listen to pump. If it sounds like it's trying to pump but the water is not moving, it could be something stuck in the pump. Remove pump and clean. Again another moderate job for a do-it-yourselfer. Unplug machine from power source before and remember some electrical equipment will hold a charge even after unplugged.
    Step 7:
    Call a professional.
  • micromaster
    If you were not learned to handle or to fix that specific work, maybe it your best bet is to call a Professional that can Service the unit..
    Just reminder Dkray, Let just say that you are trained to fix washing machine. There's so many more thing's you must have to know, make direct plan & execution and prepare for other complications.
    Remember "Don't just Look on the problem, Look beyond it and there you will see the Solutions"
  • micromaster
  • micromaster
  • micromaster
    Relax!
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Why the inlet valve is not stopping running water?
What happens with such electrically operated valves, is that a calcium (or other mineral buildup) prevents the rubber seals from stopping water flow. You need to replace the valve(s), or clean them thoroughly, using either LimeAway or CLR.
May 11, 2017 | Samsung WF337AA Front Load Washer
Do water level is not working. It will over flow
change your pessure switch. Thats the switch that says
medium low or high loads
Jun 06, 2010 | Kenmore 22422 Top Load Washer
Error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
