Question about RCA D52W19 52" Rear Projection Television
Please Help??? I have tried everything. I am to the point of kicking the entire set in and moving on. I have power and it blinks three times and that's all I get. If someone can help with an easy solution I'll by them a tv set. I am FRUSTRATED
    Genius:
  • 1,030 Answers
I hate to tell people about this when it comes to this set but i see this set all the time at the shop. This set has a procesor that when it detects a potential safety issue it shuts it down. Ussally it is a high voltage situation that causes it. technicians have a computer interface that allows them to read error codes. The only thing you can try is to uplug the set for about 30 min to hour. and try it again. I will admit i ***** have seen this work. this is where the troubleshooting will begin. WHat was is doing before it shut down. picuture issues. sound any smells. if i can help i willl be glad too
Posted on Mar 09, 2008
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
How to set my points on My 1985 yamaha yz125 wont kick over and start please help trying to sell
take your flywheel off then turn youe engine over while you watch the crank spin when the lobe on the crank moves the points to the hihest spot thats the point where you set them i think its like 10 or 12 mm
May 29, 2012 | 2003 Yamaha YZ 125
TV turns off but standby still blinking
Hello
Blinking of standby light in Sony sets are fault indications. Just count the number of blinks occur at a time, after switch OFF and switch ON your TV with its FRONT PANEL POWER CONTRO SWITCH. Make this test at least three times, and count the number of blinks keenly and inform me though Fixya. It will help me a great to rach to the faulty section, or even to the exact fault point sometimes. OK.
Feb 17, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have a 1975 Honda GL1000 standard. I replaced the points and adjusted them. When I went to start it w/the push button starter it just made a buzzing sound. I then was able to kick start it and it ran...
I own three GL1000 cycles. After fussing with the points all three now have Dyna electronic ignitions. The difference is worth the price around $200. But to your problem. When replacing points Honda sells a plate assembly with everything on it (saves time plus you get all new screws and wires to the condenser). The condensers have always been a problem with all Honda point systems. Did you install a new condenser ? Also when installing puts it is easy to ground them out. You may have to go through the whole process again to get your spark back. I believe the problem you are having is with your starter solenoid . You need a new solenoid. But for now, take off your left side cover and jump the solenoid with a piece of wire , a screw driver , jumper cable clamp, etc. You may also want to solder in a push fuse to replace the old tube fuse which at this age can be a source of aggravation when you have to wiggle the wires to get the bike to power up.
Sep 14, 2010 | 1975 Honda GL 1000 (K1)
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Green blinking power button
Sounds like an internal fuse or a power supply problem. It is worth it (I don't normally say this) to get this set fixed.
Jun 25, 2008 | RCA F36650 36" TV
Screen is Black Power Light Blinks Three Times
bad power sorse bring the tech in unless u know how to chage outthat part
Mar 15, 2008 | RCA HD52W59 HDTV Projection Television
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
RCA D52W19 52" Rear Projection Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
