Question about SanDisk Sansa e200 MP3 Player
Sansa e200 4 gb wont turn on
The battery was about dead so i charged it and now it wont turn on
  • Nicksgirl Mar 28, 2008
    the blue light comes on, but the screen is still off
  • Judit May 10, 2008
    battery on sansa e200 MP3 player will not charge when connected to computer.
    Novelist:
  • 141 Answers
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
Posted on Mar 27, 2008
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
Hi my sansa mp3 is not booting. Please assist ..
Try to reset the player. 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
Re-seat the battery. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
NOTE: If the player turns on when connected to the PC but not stand-alone, the battery might be dead and doesn't receive a charge anymore.
Mar 17, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Yea my sansa 1g mp3 player wont turn on at all
how long id you charge the battery?. You can charge for longer hour and see if it will power it.If it does no power,the battery might be dead and need a replacement.
Test the battery with the same type of the mp3 to comfirm if the battery is the functioning.If the battery is OK, that means it needs to be flashed to restored the lost memory of the mp3.
Good luck.
Mar 12, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
My sandisk sansa won't charge 4 gb
It could be that this battery is dead and will no longer charge, the cheapest replacements I have found are on Amazon.com
Mar 01, 2009 | SanDisk Sansa e250 MP3 Player
My sandisk sansa 2g wont turn on with out being plugged in at tha computer n seems to be fine when its plugged in but when its unplugged it wont work! the battery is on a full battery but wont turn on at...
The battery may show "full' but still not hold a charge, so that when you unplug it from your computer, it goes dead. I assume you hold down the power button for several seconds and it still doesn't power up? Most likely, you battery is defective.
Feb 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My SanDisk Sansa 4.0 GB does not power on @ charge.
Make sure that your sansa lock switch is in the unlocked position.
Aug 14, 2008 | SanDisk Sansa e200 MP3 Player
Frozen on.
Problem resolved. I just let it sit until battery went down far enough for "Battery" alert to come on screen.
From there I put a charge on it and everything works fine now. Probably I should have kept it charged up.
Nov 28, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
315 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
