Question about Phoenix Gold R15.0:1 1500W Octane-R Mono Amplifier Car Audio Amplifier
Need help with the wiring on amp to subs
Hi, I just bought 3 15 inch Rockford fosgate Dual 4ohm subs and the Phoenix Gold Octane R 15.0:1 Can you give me the wiring for the subs and than when the subs are on the outside of box there is two spots for the speakers on the amp I think the amp can only run with three subs like I have is two ohm is that is true what speaker termainals do i use on the amp mention above
Thanks
  • sorryman76 Mar 09, 2008
    I know that duh!!!! need to know what to wire to amp there is two spots for speakers pos neg and neg pos first or second term or part of both
    New Friend:
  • 101 Answers
Http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4 DON'T FORGET MY FIXYA RATING!
Posted on Mar 09, 2008
Where can i gt wiring diagram for phenix gold 12 dvc sub
YOU CAN GO THIS THIS SITE IVE USED FOR MANY YEARS PUT IN YOUR INFORMATION OF SUB/ SUBS AND GIVES YOU ALL WIRING POSSIBILITY'S.
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Oct 03, 2012 | Phoenix Gold Car Audio & Video
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Jul 30, 2012 | Phoenix Gold Xenon X10D4 - 10" D4...
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Amp problem, need help!!!
Sounds like one of two problems: either your subs are beginning or have gone bad, or you amp is going bad. What size power and ground wire are you using? You should be using at least a 4 gauge for both. Also what impedence are you running with the amp, ie; 4ohm mono, 2ohms stereo, etc?
Jun 19, 2008 | Phoenix Gold Octane-R 4.0:2 Car Audio...
Amp connection
Parallel would be the best way to wire them. 2 4 ohms subs to one channel wired parallel would be a 2 ohm load for that channel and if u wire them series then 2 4ohm subs to one channel would be an 8 ohm load for that channel.
May 31, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Wiring
The T10001 can drive a load lower than 4 ohms. Wire the coils of the individual speakers in series to make each speaker 8 ohms. Then wire all 3 speakers in parallel and connect them to the amp. This will give you a 2.6 ohm load.
Dec 01, 2007 | Rockford Fosgate T10001BD- Car Audio...
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Car Audio & Video Logo
122 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
