Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, replace ink cartridges. If this doesn't clear the error you may need to re-prime the ink lines to fix it. Instructions for doing this are at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
SOURCE: HP photosmart 6288, 7268 Ink Failiure System
We can really resolve the issue and however if the issue persists, we can replace the printer.
At this point, I would like to inform you to get back with the original error message.
Regards,
Sagarjd
SOURCE: hp photosmart printer c6288 giving error of ink
We have a step by step guide that will reset you printer posted at:
www.ccl-la.com/HP.htm The problem is air in the ink lines and the reset procedure will purge the ink lines and should get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
