Question about Sony Cyber-Shot DSC-F717 Digital Camera
Cyber-Shot Dsc-W70 hi the lens won't come out i have to pull it to get it to come out then its all blurry and when i try to zoom it turns to a black screen and says turn off camera and try again and when the lens doesn't come out it does the same thing
    Scholar:
  • 51 Answers
Hi
You probably have a faulty lens unit. You can make sure of this by checking that the spaces between the two rings that extend forward at switch on has the same distance between each other.
If it is not the case, your lens is damaged and needs to be replaced.
It normally costs about 1/3 the price of the camera, so it should still be worth replacing.
Bear in mind though that only Sony Service Centres can help you as the y need to setup the new lens adjustments with Sony specific software.
Hope this helps.
Posted on Mar 09, 2008
My Sony Cyber-shot DSC-W70 Digital Cameras the lens won't came and the screen showa message turn the power off and on again
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related
Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Nov 08, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
Camera lens will not come out all the way, and the screen says to turn camera on and off again. and absolutely nothing happens.
I brought my cybershot 7.2 to the beach, and stupid me did not have it in a proper camera case, and I am sure that a grain or two of sand got into the zoom lens. I used a sewing needle to no avail to try to probe this out, and in the end all I did was use my fingernail to help pull the zoom lens out, when turning the camera on, this worked perfectly after a few try's and the camera is now functioning as good as new.
The grain(s) of sand were obviously preventing the motor from opening the zoom lens.
Hope this helps.
Steve
Oct 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My Sony Cyber-Shot DSC-W120 Super Steady Shot zoom won't work!
Follow this procedure to troubleshoot if the zoom function does not operate.
NOTES:
  • The zoom function will not operate with some AE modes.
  • The zoom function is not available while shooting a movie on all cameras. Refer to the owner's manual for information regarding the functions available on the camera. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Change the Auto Exposure (AE) mode on the camera.
  2. Ensure the camera is not set for movie mode.
  3. If the camera has a conversion lens setting in the menu, set it of OFF.
  4. Reset the camera back to factory settings. To reset the Camera, please select Initialize under Settings and Main Settings 1.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Sep 20, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Hi i turn the camera on and have a blurry screen
Zoom motor in lens assembly is jammed and you need to replace complete lens assembly. DSC-T1 is an old camera so oes not worth to repair.
Jun 04, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens does not go out , can i fix myself?
Hi There,
Remove the batteries then re-install them. Turn the camera on and let me know if it works.
Mar 30, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
ZOOMING during movie rec
Zoom option doesn't work while recoding in movie mode in DSC-W70. You can adjust zoom-in or zoom-out before starting movie clip recording.
Oct 23, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Trouble with sony cyber-shot DSC-T33
try cleaning the lens first.
when taking the picture press down lightly so it will focus. Then press harder for the picture.
Jul 14, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Lens/ resolution problem
I you have been on a beach there are chances that your camera get get sand inside. you have to get it cleaned before use. to not try to operate the camera in the same condition.
Sep 15, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
