Question about Maytag MMV4205 Microwave Oven
Wireing Diagram Replaced magnatron. Can you email a wireing diagram to aid in checking circuits?
  • Maytag Master
  • 9,098 Answers
There should be one tucked away behind the control panel.
If you don't find it, feel free to reply here or to me directly via my site (see below) and I can e-mail it to you.
If you tell me what your symptoms are, I can probably help you figure it out.
You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Mar 10, 2008
Built in microwave counter top lights not working
Did you replace bulb yourself if so it may look a good bulb with filament complete but if you have touched the glass part of bulb with your fingers it can knacker the bulb.
Also the switch membrane panel traces the circuit from both the switch membrane and the lighting circuit to the power circuit board. So, I know that both the lights and the switch membrane have a common terminus on the power circuit board. Since the circuits from both sources lead to a common point,
Apr 06, 2016 | In Microwave Ovens
Can I have a wireing diagram and is there one you can supply?
SORRY we do not know the MAKE of it so we can not begin to assist
Sep 23, 2015 | Microwave Ovens
What do i do if my Hamilton beach microwave will not heat anything!!
Most of the time if the unit won't hest anything, the problem.is the power diode.
If you are familiar with working with very high voltage, open the unit, carefully discharge the power capacito using an insulated screwdriver.
Now look for any loose wiring. Reattach any loose wires to their contacts.Check and replace any blown fuses with identical ones.
Now, locate the piwer diode in the high voltage circuit and test it for function. This diode is often the only problem. I have repaired many microwaves by only replacing this diode.
If everything checks out so far, read the schematic and test the large step-up transformer. Afterwards, check the circuitry containing the magnatron.
Except for the transformer and the magnatron, the unit will be worth repairing. If the transformer or magnatron is the problem, the cost of the replacement parts is higher than a new unit.....unless you happen to have the right working part lying around.
Hope this helps. But remember, ALWAYS discharge the high-voltage-capacitor.....the charge is enough to hurt you SEVERLY!
Feb 19, 2015 | Hamilton Beach Microwave Ovens
I have a whirlpool DU940pwkb1 dishwasher that stopped. The dishes are clean and rinsed. There still is water in the bottom of the dishwasher. There are no lights on and now none of the buttons work.. Dead...
Your thermal fuse is probably bad and must be replaced.
Copy and paste this link for the fuse located in the control panel.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186
Jan 08, 2011 | Microwave Ovens
How do i replace the magnatron on a kitchen aid khms147kss
You would need to remove it from the wall, using the installation instructions here, review the safety information here, then remove the outer cover and discharge the high voltage capacitor.
Then you can swap the magnetron.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 05, 2010 | KitchenAid KHMS147 Microwave Oven
Microwave is plugged in, but getting no power, circuit ok, cannot find a fuse on the microwave.
Normally if no power is indicated, it is due to a blown fuse but if fuse has blown be careful, it because there is something wrong. Mostly its due to a problem in the power circuit.Can either be the magnatron or the diode capacitor combination.Normally the capacitor goes faulty causing the HV diode to blow. Replace the two components(diode and cap.). If it happens again replace the magnatron. Microwave truely dangerous and needs proffesional att. email me if you want to go ahead yourself
jenfou@teikomsa.net
Sep 21, 2009 | Maytag MMV1153A Microwave Oven
Have a whirlpool MH3184XPS-3 and need a shematic wiring diagram
Found a "schematic " diagram of electrical lay out and repaired the associated problem of being mis wired.
May 01, 2009 | Whirlpool MH3184XP Microwave Oven
GE spacemaker xl1800 and Pop tarts bad mix
it sound to me as if the high voltage diode is shorted. It could be inside the capacitor or out board the cap. The capactor could also be short but this is a rarity. Diodes are a cheep item . repace it and if it don't work its probably the magnatro. good luck.
May 13, 2008 | Microwave Ovens
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Maytag MMV4205 Microwave Oven Logo
87 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
