Question about Canon PIXMA iP3000 InkJet Photo Printer
When I print a test patterns, the black graph only prints half, it cuts through the middle of where it says 3eBK. Also, when I print black and white documents, sentences are missing and cut in half
    Genius:
  • 3,587 Answers
Sounds like your printer is skipping..clean and re calibrate the heads with your print manager s/w
and make certain you have current drivers. check em here
Posted on Mar 09, 2008
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Printer only printing in black and white
you might have printer set to print in black ink only check in settings if not re install printer driver then print test page if the windows logo comes out in colour and the text black everything is fine
Jul 09, 2010 | Brother DCP585cw AllInOne InkJet Printer
Canon MP 870 just turned on - black text printing ''off-register'' (Mac - Snow Leopard) - did a print test - only the 3eBK test isn't right, nor was Excel page I printed
adjust print heads... in the printer attributes by right clicking the printer the attributes should show a tool window the do this
then check if you have ink...
also check to see if you have your print set to a heaver weight paper. this could make the paper move while its printing
Dec 05, 2009 | Office Equipment & Supplies
Printer will not print in Black ink cartridg are full. what gives
Both blacks are in your print driver test pattern?
Go into the maintence menu and choose nozzle check.
It should rint a test pattern with the first grid being labled "PGB" if not your head is clogged.You can tru a solution of 20-25% ammonia to water and soak the black print head for a half an hour.Then completely dry the electrical contacts and re-install.
If that does not do it I have a more aggressive solution that requires a baster.
Jun 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wont print in color
Have you checked the driver to see if it is defaulted to black in the properties?
And have you scrolled your machine set up on the screen to be sure it did not get set to black?
Print out a test pattern and see if there is color on it. An internal test pattern. There are sample prints you can print out. If they come out in color, then your driver is most likely set to black and white.
Go into the properties of the driver and then graphics. See how it is set.
May 14, 2009 | Xerox Phaser 8560MFP Laser Printer
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
Photo's print with lines through them
Useually if your printing has lines through it it means that the head (where the ink comes out ) is had it & your up for another head. Sorry but useally big bucks I hope it's still under warranty
Oct 25, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PIXMA MP780 printing trouble
If you haven't done so, I would try another new cartridge. It is entirely possible (and occurs frequently) that you got a bad cartridge. Assuming you removed the tape from the cartridge before putting it in, this is generally indicative of either a bad cartridge, bad print head, or that heads or ink tanks may need cleaning.
The Canon support page for this printer is at:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
However, as Canon pages come up as generic pages (without the text I input for you), you will have to type in "missing black ink" (without quotes), to see the material they have posted in this regard. You will find instructions there in regard to how to clean the print heads, etc., if that is necessary. However, I would definitely try another cartridge first, especially if you haven't had that much use on the printer, such that you think these other measures may be necessary.
Please post back if you need further help, otherwise thanks for rating FixYa!
May 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
231 people viewed this question
old marine
old marine
