Question about LG X-Note LM50 Notebook
Hard disk drive replacement
Hi this is jagruti . I am having lg laptop. I am not able to start up my windows it gives me error as replace hard disk drive.
My contact number is 09967556017.
My email id is jagruti_desai@relbio.com
for_j_j@yahoo.com
Its under warranty period.
  • 133 Answers
Ur harddrive could be loose or damaged.If it's under warranty period its good to take it back,
Posted on Mar 10, 2008
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
I have INSPIRON 640m. From many months it gives an error saying "Windows deteted hard disk problem". Please back up your files and contact computer manufacturer. In details it syas WDC...
Hi govindcg,
This is an early Warning system for computers of a pending Hard Drive failure. I greatly suggest that you back up your files and replace the Hard Drive as this is the only way to fix it. Hope this helps.
Thanks
Feb 22, 2011 | Western Digital (WD1200BEVS) 120 GB SATA...
When I start my laptop I get a message "Operating
This issue may occur if one or more of the following conditions are true:
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
    Note Some third-party programs or disk corruption can damage an MBR.
  • An incompatible partition is marked as Active.
  • A partition that contains the MBR is no longer active.
  • This error is usually the result of a bad hard drive.
  • Try to do a Windows repair, if it does not work, the hard drive needs to be replaced:
http://www.geekstogo.com/forum/topic/138-how-to-repair-windows-xp/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | IBM ThinkPad T40 2373 Notebook
My laptop Dell Inspiron 1545 giving a hard disk drive error. Laptop works normal but sometimes it start producing a sound like tik,tik,tik......... then blue screen appears and when i run diagnostic it...
Its time you backup your data and contact Dell to get your hard drive replaced (in case your computer is in warranty) else order for a new hard drive compatible with your computer.
You will need your Windows CD that came with your computer, if you did not get it contact Dell about the same.
Dec 25, 2010 | Computers & Internet
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
Hi, My lenovo g550 laptop's wd 3200 sata hard disk show S.M.A.R.T failure error and does not help to start operating system. How it can be repair wituout removing them from laptop?
This warning is to let you know the hard drive may fail sometime in the near future so you should backup your data frequently.
When the hard drive eventually fails, you can replace the hard drive, re-install Windows, your programs and data.
The hard drive are devices that cannot be repaired, they are replaced.
Oct 07, 2010 | IBM Computers & Internet
My ibm thinkpad r51 is not starting up just keeping giving me error message and it doesn't recognize the hard drive in boot. I have to take the battery to stop the system trying restart the window again...
It appears the hard drive is faulty.
Does the hard disk LED flash when the laptop boots up?
Go into the BIOS configuration and see it the hard drive is detected, (then Startup - Boot - and look at IDE HDD0 it should list the make and model of the hard drive).
If the hard disk is detected it still could be faulty. To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port.
If the computer sees this as an external hard drive and you can open the various folders and files then the hard drive is OK and the fault could be the disk controller on the laptop's motherboard.
If the hard disk is not detected the it is faulty and you need to replace the hard drive in the laptop and install Windows etc. to get it working again.
Jul 15, 2009 | IBM ThinkPad R51 Notebook
Non-system disk or disk error
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
May 29, 2009 | HP 530 Notebook
Laptop won't boot.
This error arises due to hard disk failure...plz check Hard disk is detected in BIOS or not...
Feb 08, 2009 | Dell Inspiron 6000 Notebook
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
LG X-Note LM50 Notebook Logo
75 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
