Question about HP Color LaserJet 3500 Printer
Installing hp 3550 printer driver on new OSX leopard system
Added hp 3550 printer over network through hp en3700 using network address. Recognized at postscript printer. when i print it fails to connect.
Went to hp site and downloaded driver to leopard hd. File name is lj3550installer-X.sit  if i click on it a window pops up with binary.
HP side offers no instructions for installations. How do i install this driver? j
    New Friend:
  • 23 Answers
** Fixed **
I got my problem solved by followed below article steps.
http://printer-driver-download.us/hp-color-laserjet-3550-driver-download/
Thanks
Posted on Apr 13, 2013
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Posted on Mar 13, 2008
Why is my jetdirect en3700 not picking up laserjet 1020?
Laserjet 1020 is a Host-based (WIN) printer. It must be connected to a Windows PC directly.
Apr 25, 2014 | HP JetDirect en3700 External Print Server...
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Attempting to set up a Panasonic DP-1520P as a network printer
printing from mac requires a postscript driver and security utility from the panasonic website. if printing post script the device will need a postscript key and firmware. a technicians job i'm afraid
Jan 13, 2009 | Panasonic WORKiO DP-1520P All-In-One Laser...
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Jul 10, 2008 | HP Office Equipment & Supplies
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HP C6100 Wireless printer has stopped working
The HP C6100 series has had some ip setting issues. One day my printer didn't print. I checked the ip settings on the printer and got some 648.154.1.654 address. I had no clue where this ip number came from, because my router's ip is 192.168.0.1. I went into the settings of my printer and set my ip settings manual. Then I went into the router settings and reserved the ip setting I previously setting on the printer to the printers MAC address. I also set static ip address for each computer on my network. This network response issue started about one year after I purchased the printer. I still lose connection every once in a while, but rebooting the router reconnects the printer and everything sitting in the que to print starts to print. To stablize the issue: upgrade router firmware, set static ip address on your network devices, reserve those ip address in your router, , if all else fails reboot router.
Jan 23, 2008 | HP Photosmart C6100 All-In-One Printer
Network Interface
test the printer network cable for connectivity,but if the network interface fails u can use other ports like the usb port with the usb network interface adaptor to connect to the network once uve confirmed that the RJ45 network interface is bad
Dec 24, 2007 | HP Officejet 7210 All-In-One InkJet...
HP Color LaserJet 3500 Printer Logo
705 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
