Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
F2 Beeping!!!! I cleaned the oven and 2.5 hours into the 3 hour cleaning, it started beeping and said that there was an F2 error. It won't stop! Help!
  • booboo1eye Aug 01, 2008
    cooking pizza, oven will not shut off. burners still on and beeping F2
    President:
  • Kenmore Master
  • 2,651 Answers
F2 Oven too hot Replace oven temperature sensor
Posted on Mar 09, 2008
My Fridgidaire double wall oven is beeping every 2 minutes while displaying FB. How do I stop the beeping?
Sounds like an F8 error- problem with the door lock/latch (for self-cleaning mode). Could be the mechanism, control board, or wiring in between. Try unplugging (or turning off the breaker) for 20 minutes to an hour, and plug back in to see if it will reset itself. If you're lucky, you might be able to just clean gunk out of the latch area, but probably need a repair call.
Oct 20, 2017 | Ovens
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
I am trying to clean my oven. I pushed the cleaning button, it locked and said it would take 4 hours. One hour into it, it is beeping F2. What does that mean?
It means that somwthing went bad in there.... shut it down and read this tip....
Before you go working too hard to get your oven to go into the self clean mode (self destruct mode)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Nov 13, 2010 | Ovens
F2 error
F2 is a bad temp sensor, needs to be replaced.
Jun 23, 2009 | GE JKS06BFBB Electric Single Oven
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
F2 error
what is solution
Dec 08, 2007 | Ovens
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
351 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
