Question about Olympus SYS.230 3.5" Ext. Optical Drive (SYS230EXT) Drive
Download data from optical disk to iMac OS X
How do I transfer data from the SYS.230 optical disk to a iMac OS X v 10.3.9? The 25 pin transfer cables are not compatible with Firewire or USB
  • Chuckar Mar 16, 2008
    I agree with you, IB4G2008. I will need a cable to connect the SYS.230 to my iMac.
    Can you suggest where I might find such a cable that is, as you say, "mac specific" and will enable the SYS.230 to transfer data from its optical disks to the iMac?
    Genius:
  • 3,587 Answers
Yes..that's true..you'll need a firewire cable, mac specific..no easy way to do this, without proper connections.
Posted on Mar 15, 2008
  • Patrick Michaels
    Patrick Michaels Mar 16, 2008
    the firewire is compatible across platforms..best place to fine it is from the disk maker's site..who makes that disK?
Transferring data/programs from Mac book to iMac using Ethernet cable. All was going well till last minute, and it has been stuck on that for 3+ hours. Don't know what to do. Help please Elise
Assuming the MacBook has FireWire, get a firewire800 cable. PLug it into both Macs FireWire ports. Shut down MacBook, restart and hold T key = target disk mode. MacBook will appear as any other mounted external drive on your desktop. *From there, you can either manually drag files over or open Migration Assistant on the iMac and migrate user/data/ apps.
Jun 04, 2016 | Apple MacBook Pro Laptop Computer with...
IMac will not start up.Question mark in a box comes up.Also will not boot up from start up disc
The operating system on the hard drive is corrupted, or the hard drive is not available. The procedure for starting from the startup disk varies a bit depending on the model of iMac. On the oldest ones (CRT iMac) and some of the early display-on-a-dome models, hold down the "C" key while starting the computer. This will force the computer to bypass the hard drive and boot directly from the startup optical disk. (If the C key doesn't work, restart and follow the option key procedure in the next paragraph.)
On newer Macs, hold down the option key while pressing the power button until you see that the boot loader is running. You should see an icon for at least one drive on the screen, perhaps followed by another. One of these is for the optical drive. It may take several tens of seconds for the optical drive icon to appear, particularly on older iMacs. Use the arrow or tab keys to select that one, then press return to start loading the system on that disk. If you only see the optical drive icon, that confirms there is a problem with the hard drive. Try Disk Utility anyway; if it can find the hard drive, there is some possibility of recovering it, or reformatting and loading from your backup. If the hard drive icon appears in the startup option screen, Disk Utility may be able to repair the problem if it is a file system issue affecting system loading. If a fundamental system file is corrupted, you will likely have to reinstall the OS.
In the worst case, the hard drive has a physical problem. Most of the time this is mechanical (sometimes announced with repeated, regular clicking noises as the drive vainly hunts for its starting position). Rattling noises (like the head has separated from its arm and is bouncing around) are also most unwelcome. Occasionally, the problem is with the controller board on the hard drive. In this case, if you can find another drive of the same model, you can swap controller boards (doing so successfully requires observing electrostatic discharge safety procedures to prevent zapping the drive, and properly identifying and operating the latch mechanism for the ribbon cable connector that connects the board to the drive mechanism). Generally, however, you have to replace the hard drive. Once in a while, the problem is with the cable between the hard drive and the logic board. On the old Macs with IDE drives (40-line ribbon cable connecting both optical drive and hard drive on some, two such cables on other models), there may be a bad connection on one wire because the wire is not properly seated in its two-tined fork inside the connector. To reseat the wires, gently push the cable down right at the connector shell (towards the surface of the connector shell that is pushed onto the pins of the drive or logic board). Do not put a crease bend on the cable there; you're just trying to make sure the wire is in the bottom of its fork. Repeat on the other side of the connector with the end of the cable (use a fingernail to catch the edge of the cable end).
Aug 28, 2014 | Apple iMac Computers & Internet
Memorex mrx550l dvd writer
What is the specific problem you have connecting this internal drive? This is an internal SATA optical drive for a desktop with a standard 5 1/4" drive opening. Many optical drives ship as OEM devices; you will need to reuse the data and power cable from a previous drive or purchase a SATA data cable (7 pin). A locking cable can help keep the cable connected to the drive. If your power supply (PSU) doesn't have SATA power connectors (15 pin), you will need an IDE to SATA adapter. Most online cable shops have the best prices for these.
If your computer doesn't have a SATA port available, you need to add a controller card or use a SATA to IDE converter.
If your case is a ultra-small form factor, you may have a modified optical drive opening. These cases use a slim optical drive (mostly sold as laptop drives). In that case, get an external 5 1/4" enclosure or a USB to SATA adapter.
If you have the drive in the computer, press the Eject button. If that works, then the power cable to the drive is fine. Check the data cable to both the drive and the motherboard. My old computer had SATA connections on the motherboard that would not allow the cable to lock. When I bumped anything in the case, I had to check that the cable was re-secured.
What OS are you using? For most versions of Windows, your OS should have the correct driver or find it with Windows Update (if the computer is on the network). Try launching Windows Update and checking if an optional driver is waiting to be installed. I don't know if Unix or Mac OSX drivers exist for this drive. You may need a different optical drive.
The drive should now be listed in the storage devices (Computer/My Computer). If you can't read files, try another disk. If it still doesn't work, try cleaning the lens or a different drive. Some drives are sensitive to the power supply for burning optical discs.
I hope these suggestions help. Please add a comment with the specific problem and case/OS that you are using for additional solutions.
May 11, 2013 | Computers & Internet
How do i transfer songs from my pc to the mini disc
you have installed the Sony software (you don't have the driver... http://esupport.sony.com/LA/perl/swu-list.pl?mdl=MZN510 enter your OS and download, and you have the USB data cable or optical cable (optical is recommended)? plug AC adapter to mini. Open two windows of my computer. go to your music folder and copy / paste or click and drag to mini disc.
http://www.docs.sony.com/release/MZN510.pdf
see page 75
happy recordings
Feb 13, 2011 | Sony Net MD Walkman MZ-N510 MiniDisc...
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
I have mounted a new 40GB on my imac G3 and wanted to install OS ssw 9.0.4 on it, but at start up from the CD, it booth up to where it suposed to show the os type having this icon like a human faced pc at...
Thank you for contacting Fixya Support, I am glad to assist.
The "human face" icon is an indication that your hard drive is not being recognized by your iMac G3 because the hard drive is not formatted to read the Mac OS 9 software.
What you need to do is initialize your hard drive so you can
it can read the Mac OS 9.0.4 software.
Below, I have provided a link with simple steps to properly initialize (format) your 40GB hard drive
Initializing a hard disk, cartridge, or optical disk
Follow these steps and you will be able to successfully install Mac OS 9.0.4 to your Mac G3 hard drive.
I hope this helps.
Regards,
-Mactechtrainer
Aug 28, 2010 | Apple iMac G3 Desktop
Imac on boot up grey screen clicking and wurring flashing folder?
If you boot from the Leopard install DVD and click Utilities on the top then Disk Utility, you may be able to see your hard drive from there. If you cannot, then something is definitely wrong with your hard drive and you would probably have to go for professional data recovery which is quite expensive (I think around $100 per GB, but I'm not sure). This is why it is SOOOO extremely important to backup your data!
Feb 19, 2010 | Apple iMac G4 Desktop
Macintosh HD will open from desktop icon but won't stay open. I can access all but applications files using finder but Macintosh HD closes when I click on applications. I recently transferred files from...
Sounds like you may have some permissions issues - I would suggest sticking in the OS disc that came with your iMac, restarting, and holding the "C" key when you hear the chime - this will make it boot off the CD. Once booted from it, go to Tools->Disk Utility, choose your disk, and do "Repair Permissions". Once that is done, you can quit the installer and restart. If that doesn't work, the next step I would recommend is running DiskWarrior, which is $99 - this is like an industrial permissions/hard drive directory repair disc, used by many professionals. If that doesn't solve it, you will likely have to back up your user data and do a fresh install of the OS from the discs you have. Good luck!
Nov 05, 2009 | Apple iMac 17" MA199LLA Desktop
Data kit
Hi! Use iSync (included in mac OS) in order to syncronize your phone with the mac and transfer files through BlueTooth. No additional software or cables needed.
Aug 17, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Computers & Internet Logo
125 people viewed this question
Top Olympus Computers & Internet Experts
Willem.
Willem.
Paul Chana
Don A
Don A
Are you an Olympus Computer and Internet Expert? Answer questions, earn points and help others
