Question about Dishwashers
I have a FRigidaire stainless steel built in dishwasher. It does not drain properly. Any suggestions?
  • BrianIam65 Mar 09, 2008
    No air gap! No disposer!
  • 796 Answers
Hello
Posted on Mar 09, 2008
  • isaac johny
    isaac johny Mar 09, 2008
    If you have an Air Gap at the sink(chrome-dome object next to the faucet)that should be checked as well.
    Remove the chrome cover by simply pulling it up and off.
    There will be a white plastic square piece that is removeable as well.
    It is held in place by two plastic tabs--pinch the tabs and pull off
    the white square cover. Many times you'll find debris inside this tube
    that dramatically interferes with the dishwasher drain.
  • isaac johny
    Did you have a new disposer put in.. and if so did you take out the
    knockout... 2nd take drain hose off under sink and put in a bucket then
    try draining...from there work your way back to where it hoohs to pump
    underneath and check that the check valve is not blocked...
Frigidare dishwasher wont drain, can hear pump motor start
Hi Mark, this is AP and I'm happy to assist you!
I understand you are having trouble with your dishwasher not draining and making odd noises. I would suggest checking the drain hose to ensure it has not become twisted or kinked. Even if the hose is not kinked make sure it has not fallen behind the dishwasher either as this can prevent draining. Additionally, you could check the filter at the bottom of the tub to make sure no debris has clogged the filter or disposal. Other than that the drain pump could be the culprit. If so, I would recommend a local authorized technician to come out and properly diagnose the dishwasher. I hope this information helps.
Mar 15, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
FDB1050REC2 no water
If water runs back into the drain then your drain hose is not properly afixed to the top of the unit under the cabinet. It must be at the top of the unit so no more than a half of an inch of water falls back into the tub when finished.
Dec 26, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
Dec 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Standing water in model FDB1050RESO frigidaire electrolux dishwasher 2005 model
Good Afternoon Friend,
I see that you have standing water in your Frigidaire dishwasher, model# FDB105RES. I would suggest trying the troubleshooting tips below:
• If your appliance is hooked up to a food waste disposer, make sure the disposer is empty.
• Check to see if the knockout plug has been removed from inside the food waste disposer inlet.
• Check to see if the drain hose is kinked.
• Make sure the cycle is complete and not in a pause mode.
If you are still having trouble with your dishwasher not draining, I recommend contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Why is my dishwasher not draing? how can i get the water to drain?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 21, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Won't drain completely at the end of a washing cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Aug 07, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
I am looking for a stainless steel replacement panel for a Frigidaire fdbc45bab1 dishwasher.
Go to www.applianceart.com. Cheapest options. Have real stainless and faux stainless and will make sure you get the right size.
Nov 23, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Lousy Frigidaire dishwasher
I have called a service man for this problem. Thank you very much
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Dishwashers Experts
