Question about Pioneer DEH-1900MP CD Player
Error-ao resetting it
  • 2 more comments
  • Roberta Geier Mar 10, 2008
    I need to reset the clock to DST.
    how do I reset the clock?
  • jason53 Mar 16, 2008
    error ao
  • Anonymous Sep 24, 2008
    error-ao problem
Offtopicforum shittypantyes
Posted on Apr 19, 2008
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
AO SMITH VOLTEX ERROR CODE ELEMENT ON HEAT PUMP FAULT ON SCREEN
Copy following link
http://waterheatertimer.org/pdf/AO-Smith-heat-pump-service-manual-321547.pdf
Contact AO Smith for qualified technician in area.
Don't buy expensive water heaters.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 09, 2013 | AO Smith PHPT-60 60 Gallon Voltex...
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
Error AO ON MY HAYWORD H SERIES POOL HEATER
The AO mindicates an open prover switch ,, here from Hawward site .
If the blower prover switch opens unexpectedly during operation the control will
shut down and attempt to re-light. If the switch does not close after the blower
starts the control will go into lockout with the blower running. Automatic reset is
immediate after error is corrected.
May 08, 2010 | Hayward H Series Pool & Spa Heater 400k...
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
I am getting error code AO and the temperature
its most likely diplaying a code... is it code 21? that usually will follow ao. first make sure the door is securely on, if not make sure it contacts the switch
Nov 14, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
AO error
This error is produced when the blower prover switch does not close after the blower starts, the control will stop the ignition and go into lockout. Automatic reset is immediate after the blower prover switch closes.
If you keep having this problem, contact a reputable service company, especially if it's under warranty.
The link to the owners manual is below, it references fault codes, etc..
Hope this helps.
http://74.125.95.132/search?q=cache:4mAdY7bLfoQJ:www.haywardnet.com/products/Manuals/pdfs/Manual227.pdf+hayward+AO+error&cd=7&hl=en&ct=clnk&gl=us
Sep 16, 2009 | Hayward H Series Pool & Spa Heater 400k...
I get error ao on my cd player when it reads a cd
are you useing cd rewrights some cd players dont like them ? have you tryed a cd cleaner in it ? if not try that if it dont do the job your find the laser needs to be reset in side the cd player this sometime costs more that what the head unit is worth it might be cheaper to buy a new one . let me know how you get on
May 29, 2009 | Pioneer DEH-P2900MP CD Receiver...
Error Message AO
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Mar 09, 2008 | Pioneer DEH-1900MP CD Player
Hitachi Aircon
According to the error codes for hitachi, there is no AO code. The codes on the code list are all numeral.
Jan 09, 2008 | Heating & Cooling
Pioneer DEH-1900MP CD Player Logo
192 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
