Question about SanDisk Sansa e200 MP3 Player
"Load main image failed. Switch to Recovery mode"
After I update firmware "Load main image failed. Switch to Recovery mode"
  • pickols8 Mar 12, 2008
    I have same problem. Just updated firmware on e260 and now I get message Load main image failed Switch to recovery mode and I can find no reference of how to switch to recovery mode
  • myfarm Mar 14, 2008
    I have the same load main image failed problem. I use my e250 with rhapsody. the player started crashing the program, so I updated the firmware and this happened.
My e260 is saying "load main image failed switch to recovery mode" what that means
Load main image failed, this is a firmware error, (this does not have software like a computer)
Recovery mode, the player tried to recover from the error.
The player has firmware updates that where put out by the MFG because of problems.
You have to read the manual, carefully and follow it to the T.
because you need to update the firmware on the player.
This is there website.
http://kb.sandisk.com/app/home
Feb 08, 2010 | SanDisk Sansa e200 MP3 Player
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Load main image filed switch to recovery mode
you need to update the firmware on it..i had the same problem but then it started working again once i added the firmware to it
Apr 16, 2008 | SanDisk Sansa e260 MP3 Player
Switch to recovery mode...
go here
good luck
please mark the post with a fixya!
Feb 12, 2008 | SanDisk Sansa E280 MP3 Player
Load main image failed, Switch to recovery mode"
If it still plugs in and works properly, you can try to format it or try to update its firmware with the firmware updater that you can download from sandisk.com and then click on download.
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 30, 2007 | SanDisk Sansa e200 MP3 Player
Load main image failed?
Hope this would help. Have you updated the firmware of your player? Try updating the firmware of your player. When the player is turn off slide the hold switch for it to show orange/red color. Then press the Record and the menu button until is shows on the screen welcome to recovery mode. Then go to sandisk website and download the firmware update and install it to your computer. When it ask you to connect a device connect the player and update the firmware of the player. If the update is successful then it would ask you to choose a language. Hope this helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
427 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
