Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint hss25gp Not keeping cold or freezing
I need some help... My 3 year old side by side is not freezing and staying cold. Need advise asap
  • 1 more comment
  • Anonymous Jun 06, 2008
    MOTOR RUNS ALL THE TIME
  • Mary2529 Aug 17, 2008
    My refrigerator stopped working. The water & ice also does not work. When I try to get water or ice the light turns on then slowly turns off. I do not hear my motor running but when I open the doors my light turns on.
  • Anonymous Aug 27, 2008
    is not working just ticking
  • 828 Answers
Check and clean the condenser coils where heat is transfered to the room air. If they are plugged with dust it will cause your problem. Check the back wall of the freezer for snow. If snow is on the back wall you have a defrost system problem.
Posted on May 23, 2008
I have the same thing and there is no coils the back is smooth.
Posted on Jun 28, 2008
Coil freezes
perhaps the drain is plugged in the freezer.
Have you checked this, please let me know what you find and we can go from there to figure this out.
May 12, 2008 | Hotpoint HSS25GFP Side by Side...
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Freezer has to be thawed out every 2 to 3 days. The refridgerator side isn't staying cool enough to keep milk from spoiling. It is a Hotpoint Model #HSS25GFTA WW and is only 2 1/2 years old. It is a side...
Could be multiple problems. First, check the freezer compartment and make certain that the freezer fan is running. This fan moves cold air from the freezer compartment to the refrigerator. If it's not running, inadequate cold air gets to the refrigerator.
Your having to defrost manually sounds like there could be a problem with the defroster circuitry; however, check out the fan operation first.
The fan should be at the top of the freezer. There is probably an access panel you can remove to see if it's turning. However, you should be able to hear it if it's turning.
If the fan is not turning, you will need to remove it and replace it.
Oct 11, 2009 | Refrigerators
Hotpoint hss25gfphww refrigerator is not cooling on either side. All of the sudden freezer not freezing, fridge not very cold. Any suggestions? Fridge only 5 years old.
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
Jul 20, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint sxs compressor stays running.
Fasnipe, it sounds like you are starting to lose the gas in the unit. Fairly soon, you'll see that the unit will fail to keep things cold. If it is less than 5 years old, you may have a warranty. If more, I suggest you get in a technician when the problem begins to impact the ability to keep food. You cannot fix this yourself.
Jan 24, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore
problem has been almost certainly caused by freezer door not being completley closed allowing warm humid air into freezer, (do not say this could not happen because it often does), sollution, turn off defrost overnight, turn on following day, within 24hrs unit will work ok. Regards Adviso
Aug 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
119 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
