Question about Pioneer DEH-1900MP CD Player
Error Message AO
The unit will not allow me to play or eject a cd the message error AO is displayed on the display
its says error-Ao
  • 1 more comment
  • kiki2687 Apr 09, 2008
    My player is doing the samething. error message ao
  • notoriusbug Aug 14, 2008
    Same problem - I'll give the harness thing a try tonight
  • evbrad2002 Aug 17, 2008
    Same problem. error-ao message after my battery died from leaving lights on. Jumped the car off and then the error message. Unplugging the harness for an hour+ did the trick! BTW, I also called Pioneer customer service and this was their suggestion also. I didn't have the removal keys so I had to go to the Best Buy that installed it to have the head unit pulled so I could disconnect the harness. Pioneer suggested leaving it unplugged for an hour to ensure all of the voltage was drained from the capacitors to allow the unit to reset. BTW, I tried pulling the fuse to the radio in the fuse panel first. This did not work. Pioneer discouraged unhooking the positive battery cable of your car because voltage spikes can occur when hooking the battery back up and result in damage to the head unit.
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Posted on Aug 24, 2008
  • 3 Answers
Same problem. Battery went dead and I received the error AO message when I tried to play a CD. A Circuit City installer pulled my deck with the extraction keys and grounded out the deck by applying one of the wires to the small indentation on top of the deck. That reset the theft prevention on the CD player and I was happy until my battery went dead again. :(
Posted on Nov 24, 2009
Okay. i have had the same problem before. along with that problem, if i push buttons while in another mode, ie. fm/am radio, it's like the buttons on the deck were re-mapped or one button does a different action than it should. now, i found that when i connected the radio, i had the faceplate on, with the battery terminals still connected. this apparently sends a surge or something to that effect through the radio, causing the cd player to not work, the buttons re-mapping and so on. in order to reset itself, you have to unplug the harness from the back. take the face plate off, then wait about 30 minutes just to be sure that all "left over" power is released. after all that, just plug the harness back in, with out the face plate attached, then put the faceplate on. it should work. after the first time it happened to me, i did everything to replicate the problem, then found out about the faceplate causing it. trust me, try it out and it'll work everytime.
Posted on May 07, 2008
Clarion CD error code E5
you can find almost all error codes on google by searching unit name and error code
Aug 09, 2014 | Clarion Car Audio & Video
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
My 2001 Landcruiser will not play dvd/cd. It gets
I have the same exact problem:2001 Landcruiser will not play dvd/cd. It gets stuck. Display of dvd error shows. DVD can not eject. Please let me know if you got it to eject. I tried disconnect/connect the battery for full 5 minutes but did not help.
Apr 20, 2010 | 2001 Toyota Land Cruiser
Mech Comm Error
sounds like they may have forgotten to take out transit plugs from radio which holds cd mechanism in place when shipping unless you got a new radio thats a dud? but that may also mean dealer didnt check operation of new unit after replacement if replaced which is what usually needs to be done when this error message comes up
Aug 06, 2009 | 2005 Jeep Grand Cherokee
Error ao pioneer head unit
If the discs PHYSICALLY get stuck, then the mech is damaged. A local shop MAY be able to fix it, but it might be a better investment to just replace the radio.
Aug 04, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-1900MP error AO
I have the same problem CD will not eject and getting error :S
Oct 19, 2007 | Pioneer DEH-1900MP CD Player
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
CD Changer MEC ERROR
i have the same problem!!!
do anybody knows how to fix it??
thank you very much
Oct 26, 2006 | Sony DHC-ZX50MD Shelf System
Pioneer DEH-1900MP CD Player Logo
568 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
