Question about MSI Wireless-G RG54G3 Router
MSI RG60G : Firmware upgrade failed or ROM not burn in flash completely
The status LED of my router is flashing/blinking very fast. Yesterday, i tried updating my firmware from the MSI website (http://global.msi.com.tw/index.php?func=downloaddetail&type=firmware&maincat_no=131&prod_no=1061)
it turns out that it didnt do the job well and the router is currently not accessible. I tried pushing the reset button, but the status LED still flashes very fast. The manual does not provide any solutions to this problem. Can anyone help me?
  • Katallyn May 16, 2009
    Markk7171 and how u do this if have no conectiviti with router? and al led are on . I have rg60se.
    Sergeant:
  • 221 Answers
Did the firmware install completely, or did the download get interrupted?
In the manual it should tell you how to log into the router. Have you tried doing so?
If the download was interrupted then you have a corrupt version of firmware that leaves your router inoperable. The only way to correct this is to reinstall the firmware.
Posted on Apr 16, 2008
HP Designjet 500 has a locked screen. I have been trying to get the plotter to run on our new computer and it locked up after installing the current Firmware and driver updates. Any suggestions would be...
Dear Friend, It's a serious issue what I understood & confusion is control panel locking facility not avail in this model, how its locked?.. Simple method to catch the faulty part through power LED behaving s..(Power led located on power button)
# LED is OFF - This indicates that the Power Supply Unit is
completely dead. Try the following:
1 Check that power cord is connected correctly to the Printer and to the Power Socket.
2 Replace the Power Supply Unit
# LED is ON (all the time) - This indicates that the Main PCA is completely dead. Replace the Electronics Module
# LED is Flashing - A problem has been detected with the previous firmware upgrade. Try re-send the firmware upgrade file.
# LED Flashes twice every few seconds - The Printer cannot detect the Interconnect Cable. Try the following:
1 Check that the Interconnect Cable is connected correctly to the inter connector PCB & Electronic module.
2 If the Interconnect cable is connected correctly and the LED continues to flash twice then replace the Interconnect Cable
LED Flashes 3 times every few seconds - The Printer cannot
detect the Front Panel. Try the following:
1 Check that the Front Panel is connected correctly to the Interconnect PCA.
2 If the Front Panel is connected correctly and the LED continues to flash 3 times then replace the Front Panel
LED Flashes 4 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module
LED Flashes 5 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module.
Now U decide that whether firmware uploaded properly or not?..if not its sure that Electronic module gone.. you have 2 replace it..
Any further help/query pl reply, best of luck..
Oct 02, 2013 | HP DesignJet Office Equipment & Supplies
Power led is blinking after I upgrade firmware
Something went wrong during the upgrade of your firmware. If you were upgrading the firmware from Linksys website you need to call their tech support and have them replace it for you. If you were trying to hack it with a 3rd party firmware you probably need to go buy another one and maybe consider using the firmware it comes with. You cannot restore the device because the flash killed the restore function. Your device is cooked. Put some BBQ sauce on it and serve it for dinner.
Jan 03, 2010 | Linksys WRT54G2 Wireless Router
Unable to upgrade Zebra TLP 2844-Z printers firmware
What is the problem if this works?
May be there is a problem on the boot rom!
Jun 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
MSI RG60G Router Problem (AGAIN)
give the static ip address then you solve and update the firmware
Jan 28, 2009 | Computers & Internet
Forgot password and username
Yes there is.
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the power off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if the LED light flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
Nov 24, 2008 | MSI Wireless-G RG54G3 Router
DI-524 status led not blinking
Here are the instructions
  1. Make sure that you have a copy of the latest firmware and it has an *.exe file with it. Because the router's configuration page won't be available, you'll be needing the exe to some sort of force the firmware upgrade procedure.
  2. Unplug everything attached to your router except the power cable and LAN cable connected to your pc.
  3. Configure your TCP/IP with this info: IP:192.168.123.253, Default mask:255.255.255.0, Default Gateway:192.168.123.254 and DNS Server:192.168.123.254 (Use only 1 DNS server). Save this new configuration and reboot your pc.
  4. Unplug the power cable to your router as the pc reboots. When everything is up and running, plug the power cable. The status led will be flashing like crazy. It's normal.
  5. Use the exe file to upgrade your firmware. Make sure that the utility file (exe file) is able to recognize your router or else you won't be able to do a firmware upgrade. Now this may take a while, keep pressing the Refresh button to recognize your router. Once recognized you would see there 192.168.0.1 crash. Once you have this, you can now press the upgrade button.
  6. Wait for a while until the unit finishes the upgrade and once done, I think you have recovered the life of your router from the pits of hell. Hahahaha.
  7. You can now unplug the power of the router and restart your pc, see if everything is doing fine.
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
Nov 24, 2008 | D-Link AirPlus DI-524 Wireless Router
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
MSI wireless G RG60G fast bliking wan.
hello!
fast blinking wan light may indicates that it receiving or sending data. try the ff and see if this may work:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 24, 2008 | MSI Wireless-G RG54G3 Router
MSI ROUTER RG60G
Reset the router as factory setting and check it,
making factory reset is press the reset button continous for 30 -60 sec.
Mar 03, 2008 | MSI Wireless-G RG54G3 Router
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
MSI Wireless-G RG54G3 Router Logo
894 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
