Question about Samsung SGH-E370 Cellular Phone
FM Radio Hi, I am using samsung SGH-E350. I am not able to get FM radio even though connected my earphones. I tried so many frequencies but nothing is responding.
    Brigadier General:
  • 7,752 Answers
Take the phone into a mobile center and have them try to set it up or see if they is a problem with the mobile.
Posted on Jun 15, 2008
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
Optus won't accept my unlocked telstra samsung sgh-a412, why?
It may be due to the radio frequencies that Optus use being not be compatible with the Samsung sgh-a412 available operating radio frequency range. TThe mobile data radio frequencies may be different and the phone might not work on the radio frequencies used by Optus.
The Federal Government sells radio frequencies to each carrier to use and there may be a problem with the Samsung-a412 working on the Optus allocated radio frequencies assigned to Optus.
from further research on my part
The phone you have uses utms 850 mega hertz radio frequency G3 mobile data and this frequency band is not used by optus they use utms 900 mega hertz radio frequency G3 mobile data .
May 25, 2017 | Computers & Internet
Problem with my earphones.samsung shg-j700
go to options while you are listening to music & then select "earphone on"
Jul 24, 2012 | Cell Phones
Why my samsung s5570 Radio doesnt play FM stereo Sound
I queried this and was told you can only listen to the FM radio through earphones.
Nov 22, 2011 | Samsung Galaxy GT-S5570
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
No sound from radio on sansa clip. mp3 playing still works fine.
Did you accidently pause radio. put sansa in radio mode and push the play/pause button.
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
Samsung E250 Radio
Radio works only with the headset plugged in which is used as an antenna, I believe only original headset works..
Nov 11, 2008 | Samsung SGH-U600
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Radio wont work (brand new mp3 player)
some of these mp3 players use the headphone wiring as the antenna...are you pugged in? also try removing the batteries for 30 minutes, and then restarting
May 31, 2007 | Samsung YP-K5 MP3 Player
Samsung SGH-E370 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
