Question about Canon PowerShot A520 Digital Camera
Bent lens I have dropped my canon digital camera. The lens will now not retract and it is bent at an angle. When I turn it on it just says "lens error restart camera" Can i fix this myself?
  • Canon Master
  • 4,738 Answers
From what you describe it doesn't sound good. But here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
Posted on Mar 09, 2008
Hi This morning my canon sx200 is dropped when it was open and i found little bent in lens cover. I could able to take picture also at that instance. But when i tried to turn off, lens could not able to...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 22, 2011 | Canon PowerShot SX 200 IS Digital Camera
Lens Error - won't retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Feb 17, 2010 | Canon PowerShot A540 Digital Camera
The lens want close due to being bent
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 09, 2010 | Sanyo VPC-E760 Digital Camera
Lens error
yes, this happened to me, what you have to do is "snap" the lens back in place, if it is bent anyway. if it is not bent and it says lens error, does it the lens come in and out? if not then it is bent if so then there is a hardware error in the switch and you will have to send it to a profesionall. :) hope i could be some help :)
Jun 17, 2009 | Canon PowerShot SD770 IS / IXUS 85 Digital...
I dropped my camera and the lens won't retract. The screen reads lens error restart camera. Even though I have removed the battery to restart the camera, it won't correct its self. The lens stays out.
When you reset the camera you should be able to hear the gears of the camera lens turning. The problem is that the lens is out of alignment so the lens can't slide back in. As the gears are turning, straighten out the lens (you might have to try forcing it in different directions if it's not obvious which way the lens is bent) and it should slide back in. You obviously want to be gentle enough to not break it, but sometimes you have to use a little bit of force based on the severity of the drop. You also might need to try a few times since the gears will only run for so long before stopping. I have fixed a few cameras this way but if the lens is bent too far out of alignment you'll have to get it profesionally fixed.
Apr 27, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Camera fell off TV tray; lens bent and won't retract
i had the same problem. just force the lens back into place. I did that and it worked perfectly!
May 15, 2008 | HP Photosmart R927 Digital Camera
Canon PowerShot A520 Digital Camera Logo
170 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
