Question about LG GL6000ER Air Conditioner
Non cooling after sometime of running, ac stops cooling bcoz ice is frozen on air filter and coils. wat can be the problem and wat shud i do?
You problem could be a relay
when relay don´t disconnect the fin, pipes can be frozen
Posted on Apr 29, 2008
  • 236 Answers
Check the indoor fins and air filter if dirty, so if its dirty cleaning is needed specially the indoor fins it should not be block with dirtsnon cooling - 6702929.jpg. But if it is clean then you need a qualified technician it may need additional gas.
Posted on Mar 09, 2008
It cools great when first turned on. After so many hours of cooling it stops cooling
Have you checked up in filter area at ceiling to see if fins are frozen or frosted bad? If they are dirty, they can cause frost/ice and AC goes in to fan only until frost/ice is gone. When did unit actually get a good cleaning last? Too many registers closed or blocked can cause freeze up as well. Does this unit have ducted or non-ducted system?
Aug 18, 2013 | Dometic Rooftop RV Air Conditioner
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Not cooling properly. dismounting the front panel showed formation of ice on ac tubes
ice forming on the evaporator coil (you called it ac tubes) is a common sign of 'low' air flow across the coil.
The evaporator coil will 'ice' if the air flow is restricted.
This usually happens when the filter and or coil becomes dirty.
If the filter is changed often (when dirty) then the chances of the coil becoming dirty are reduced.
In any event - you must have a 'clean' filter and a clean coil.
The filter is usually made to be 'washed out,' and the coil can be cleaned with a wrag - or brush of some sort.
The goal is to make sure the filter and coil are both clean.
Other things can cause a coil to 'ice,' but are less likely.
a) low on refrigerant - not likely because the system is 'sealed' and the chances of losing gas are remote unless it's an older AC and has been 'opened' in the past - which improves the chances of a leak.
b) a problem with the fan motor - i.e. cutting off and then back on - or - not running as fast (both will reduce the air flow) as it should because of internal problems.
c) in a room with a 'low' load - i.e. the outside temp is low and the room is cool - thus causing a low load situation. This too is not likely as most AC's are being run because it's hot in the room.
Bottom line - is I would make sure my filter and evaporator coil are both clean and unrestricted.
good luck!
May 09, 2010 | LG BG8000ER Air Conditioner
I have a RUUD RCBA-3765G Coil. When my AC stopped cooling I went to the basement and opened the access panel. When I looked at the coil it was frozen completely, the insulation was frozen to the front of...
This could be caused by a low refrigerant charge or dirty filters restricting the airflow. Also it will happen if the indoor fan isn't running.
May 02, 2010 | Heating & Cooling
Ac will not cool down
first you need to determine if the furnace coil is frozen or iced up. The water around the furnace means that the water is not draining where you want it to go. This can be from a blocked drain line or a frozen coil. The fact that the system is not cooling may mean that the coil is blocked. Turn on your blower only and let the air flow warm the coil if it is frozen it will start to melt. The system is then low on charge or the air flow is blocked by a filter or bad blower
Aug 13, 2009 | Ruud UBHC Air Conditioner
Air conditioner motor is running but not blowing air
Sometimes a shorted capacitor causes the fan to run backwards. Stopped up coil,frozen coil. If frozen turn ac of fan on the thaw. Pull panel off of Air handler and check roration. No problem Rusty
Jun 05, 2009 | Heating & Cooling
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
Price to replace cooling coil on WeatherKing 12AJA4801
If the coil was frozen over it tells me there is a different problem. If the coil is frozen over try this. turn the circulating fan to the on position and the sir conditioning to off . Let it run this way for 1-2 hours to melt the ice and re-establish the air circulation. Then turn the a/c back to the cool mode and see how it performs.
Lower temperatures during evening and night conditions can cause coils to freeze over. Running you A/C with the fan in the on position generally takes care of this problem when you are cooling.
Jun 04, 2008 | Weather King 10AJA2501AH Air Conditioner
Non cooling
If the running capacitor is bad the compressor will draw above average amperage and the overload protector will cycle the compressor off. You should take it in for service.
May 08, 2008 | LG GL6000ER Air Conditioner
LG GL6000ER Air Conditioner Logo
147 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
