Question about Symphonic WF20D4 TV
Screen Damage!!!! i have had screen damage on this tv once before. I have not seen it again since it first happend.(it stopped for about a year) and now the screen damage is back .. can anybody explain to me what it is and how to solve it?
  • evansblue5 Mar 18, 2008
    on corner is like purple and makes the tv color purpleish
    Scholar:
  • 135 Answers
Hi there!
If you refer to screen damage, what does it look like? Perhaps no picture,Colours gone bad or blurry picture? Jus004
Posted on Mar 09, 2008
I have a 46" flat screen samsung TV which I bought
change your tv configuration channel type is probably cable instead of air
Nov 09, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
When we turn the power on, the green power light goes on, stays on for about 5 secs, turns off, and then turns back on. This happens continuously until we turn off the tv. The screen is blank with no sound...
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)! The backlight inverter is what lites the screen for viewing!
I would recommend to repair immedately and stop trying to turn it on over and over...this will futher damage your tv and cost more to repair in the long-term.
Please rate if this helps! :D
Apr 19, 2011 | Sanyo DP37647 37 in. LCD TV
I have a Sony Bravia LCD TV. Half the screen has colored lines instead of the picture. What would cause this and can it be repaired? Or should I just purchase a new tv? This one is less than two years old.
The problem is with the lamp of the television, it is having some fault that is why it is giving you a half screen with colored lines, once it becomes completely damaged, there will be no display on the screen.
The lamp is fixable, and you do not need to replace the television.
All you need to do is to have a repairman check and replace the lamp of the television and it will be okay once again. This is quite affordable.
All appliances are bound to develop one fault or the other, and there is no fault that is beyond repair except for some repairs that could cost as much as getting a new television.
It does not matter the years it spent, an appliance can develope fault the moment you get it home from the retailer that sold it to you.
Simply replace the lamp and your television will be in good condition once again.
Take care and good luck
Oct 25, 2010 | Sony Televison & Video
Inside screan is broken
Sorry,if the screen panel is broken or damage is not worth fixing.Because replaced the screen panel will cost the same as a new tv.No,where u can buy the screen panel,but the tv corporations themselves and it 90% of the tv.It limmited produced,that why damage or broken on any LCD or Plama tv screen panels are not worth repairing.Now ur tv only can be salvages for electronic's board parts that it.
Jun 10, 2010 | LG 32PC5DVC 32 in. Plasma EDTV
When i try to flip my sidekick 3 sumtimes it gets weird displays
Yep, it will. The flex cable is probably damaged
Here is a guide for the replacement of the lcd screen:
How to replace Sidekick 3 LCD Screen
find the screens here:
Sidekick 3 LCD Screens
I hope that helps everyone.
Nov 23, 2008 | T-Mobile Sidekick® 3 Cellular Phone
PSP Slim, picture problems
If he bought it from best buy, ask for a two year reeplacment plan. after that, you tell them what happend to your psp. by the way, the replacment plan is only $29.99. They will either try to fix it, or they will give you a new psp, the same exact type as you said psp slim, for free. But heres a catch. after you use the replacment plan once, you may not be able to use it again. good luck. P.S. what happend to your nephew, is what happend to me.
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
Xbox 360 repair
TRY GETTING A NEW PIECE TO PLUG INTO TV. ALSO TURN ON TV BEFORE CONSOLE. IT HAPPEND TO ME. I DONT KNOW WHY THOUGH.
Apr 14, 2008 | Microsoft Xbox 360 Console
Samsung rear projection tv have vertical black linens up and on tv
you have a bad dmd module and it cost around $750-$800
Happend, because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years im seen that only on hlm and hln series. Probably
happens on other models. but, i never seen that.
Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom righ side of module and 4 of them
from around dlp unit unpulg all cables ( i think
3 cables ) that it. Same way install new one in.
but you will need to adjust a module position to get picture to fill whole screen.
Jan 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Menu, volume and channel emblems will not show up
take your set to a tech the tv system control circuit might have damage, that circuit controls OSD,channel memory. it is an ic that controls that circuit along with other components.good luck.
Mar 26, 2007 | Toshiba 43H70 43" Rear Projection...
Flashing green on screen
did he spay something in ? or more like a vacuumed or didn't see?
Jan 19, 2007 | Hitachi 51F500 51" Rear Projection...
Symphonic WF20D4 TV Logo
80 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
