Panasonic sa-ht95 home theatre Display shows
Display shows 'no disc'
DVD does NOT spin.
  • 3 more comments
  • nojofox Jun 01, 2008
    About six months ago I had an issue with the dvd player as well it would play but no picture would show. Now I have the problem with the no disc issue
  • moradabad Aug 13, 2008
    I have the same problem with my Panasonic SA-HT95. I have no idea what to so to fix. Can anyone help???
  • derujose Nov 30, 2008
    The disc does not spin?
  • mijohn48 Apr 09, 2009
    No Disc comes up and it doesn't spin!
  • Anonymous Mar 19, 2014
    only shows please wait when powered up
    Problem Solver:
  • 8 Answers
Replace traverse assembly.
Posted on Oct 02, 2009
Where can I purchase a cooling fan for my Panasonic DVD Home Theatre Sound System?
How to Fix Panasonic SA-HT75 Fan - Simple Always ON ...
? 2:56
https://www.youtube.com/watch?v=ypL0o5zF_vU
Aug 13, 2012 - Uploaded by Michael "Jack H." Miller
The Panasonic SA-HT75 (and subsequently lots of otherPanasonic ... them from shining: The fan is set to come on and cool your system when the unit ... this out my son he's 8 and he mode yards all summer for a surround sound .... unit but was defective I need the little engine that the dvd is spinning up .
Nov 29, 2015 | Panasonic Audio Players & Recorders
My Panasonic Blu-Ray Home Theatre System Model sa-bt207 unable to read any disc, music or DVD. How do I solve it, never really used the disc part before, is the laser just dirty?
Firstly I would run a Disc cleaner before I did anything else. They are cheap and effective. You can usually find them in computer or electronics stores(Radio Shack for instance)
Nov 03, 2011 | Panasonic Home Theater System System
Panasonic SC-HT95 display says "NO DISC" after reading DVD
Hi,you need to have the laser replaced in the unit.
Aug 09, 2009 | Panasonic SC-HT95 System
"NO DISC" and no power to fan--Common Cause???
REPLACE THE LASER- THE FAN WORKS WITH VOLUME,AS YOU GO LOUDER THE FAN STARTS TO WORK
Jul 19, 2009 | Panasonic Home Theater System System
Panasonic sa-ht95 dvd home theater sound system no read discs.
You might try taking the back off and using a can air on it.do not use the can of air up close. Use it in short bursts. Also use a dvd cleaner the laser eye may be dirty. You can clean it off with a q-tip and alcohol. Make sure it is dry before use. Wait at least 5 minutes to be safe. Un plug it first. Be careful not to touch anything in there especially the boards, They are sensitive to electricity in your body. Most techs wear a static wrist starp.
SA-HT650 Home theatre system Disc does not spin
i think the problem yet, is not the motor.it will start spinning once the tray or its loading sequence is close or it says close.better check the rubber belt for tightness.because if you can manually operate the loading, it only means the its not totally closed.there is a small switch just under it that needs to be closed.the rubber belt can be found under the cd tray.i suggest the you call a tech to open the unit up for further troubleshooting and advices.
May 07, 2009 | Panasonic Home Theater System System
No Disc
you need to replace the laser/optical
Dec 07, 2008 | Panasonic SA-HE70K
Panasonic SA-HT 955 Home Theatre System
The F61 is the shorthand for protect mode. This indicates a problem with the output amplifier section. I don't have a listing for your specific model, but a similar one HT95 lists IC501 as the output amp chip. Check for the marking on the large black IC attached to the heatsink it may be RSN311W. If so, this can be ordered using part number: RSN311W64D-P for $95.20 from tritronicsinc.com.
Hope this helps,
Dan
Aug 28, 2008 | Panasonic Home Theater System System
Panasonic home theatre system 5 cd changer says no play when inserting dvd
Try cleaning the pickup with a cleaner disc-i'm assuming this unit IS supposed to play DVDs, of couse!
Stan
Mar 19, 2008 | Panasonic sa-ht930 Home Theater Audio...
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Jan 27, 2008 | Panasonic SC-HT680 System
Televison & Video Logo
754 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
