Question about SanDisk Sansa m240 MP3 Player
How do I reset or clear all my music files on my Sansa m240?
I bought this at a retail and it really didn't give me instructions on how to use it. I figured out how to download but I want to reset my music and start a whole new list and that's where I'm having a problem.
I use windows media player to sync my music. I cannot find a way to delete those old songs and replace them with new ones. The file wont pop up to delete, and everything i've tried wont work.
  • 148 Answers
Connect your M240 to your computer via the usb, go to My Computer and you should see it listed there as M240. Double click to open and delete the files you want to remove.
Or you can use windows media player .. by going to FILE, OPEN and choose the M240 (will located under My Computer).
Posted on Mar 09, 2008
SOURCE: Sansa m240 MP3 Unknown Artist
Don't rip the CDs with Media Player. Use Sansa software.
Posted on Jan 16, 2008
  • 83 Answers
SOURCE: Synching songs to Sansa m240
YOU MIGHT NOT HAVE SYNCED RIGHT....YOU MIGHT NEED TO DRAG AND DROP YOUR FILES OR CONSIDER GETTING A SANDISK E200 OR A CX00 VERSION MP3 THEY ARE MUCH EASIER TO WORK WITH
Posted on Feb 21, 2008
SASSYBEAR
  • 148 Answers
SOURCE: How do I reset or clear all my music files on my Sansa m240?
connect your M240 to your computer via the usb, go to My Computer and you should see it listed there as M240. Double click to open and delete the files you want to remove.
As for the lock .. check on the left side of the player slide the HOLD button UP to unlock the files.
coolfixya
  • 82 Answers
SOURCE: how do you delete songs off of a sandisk sansa m240 music player
In My computer right click on the mp3 player and select format..then it will delete all songs..
Posted on Feb 28, 2009
  • 280 Answers
SOURCE: deleting songs
In the player go to Settings->USB and set MSC. Now connect it to your computer and you'll be able to find the songs in the removable drive.
Posted on Jul 16, 2009
How do I edit my sansa m240 without the appropriate software?
You can connect the Sansa m240 to your pc, and in my computer you shall see the player. You can add music by dragging the mp3 files to the music folder on the player. You should see your other music currently on the player, in those folders.
Jun 06, 2009 | SanDisk Sansa m240 MP3 Player
I need the installation disk for sansa m240. i bought the mp3 sansa m240 from a friend, but he lost the installation disk. i need to install it in my computer, so i can download songs to my mp3. thanks
hey guys goto to this webpage to download the installation disk web site this might help. I tried my best !
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
or
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Good Luck Guys
Mar 04, 2008 | SanDisk Sansa m240 MP3 Player
Lost my instructions to my sandisk sansa m240 mp3 player
I looked long and hard and was able to find the answer.. It should not be this hard but here you go; Its the link to the pdf file:
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_ug_Eng_m200.pdf
Glad to help!
Jan 10, 2008 | SanDisk Sansa m240 MP3 Player
not the best solution perhaps, but I just formatted the disc and all data is gone. Had to do it as for some reason, the old music files weren't showing, but disc space was taken.
Dec 13, 2007 | SanDisk Sansa m240 MP3 Player
Reset button
This is a well know fault with the m240. The easiest fix is to take it back to the store you bought it from and get a replacement :)
Jun 12, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk sansa problem
This error message may largely be due to the corrupted Music Database file that the Sansa M240 creates to maintain an information pool on the music files downloaded to it. Normally, if you are unable to completely format the player in Windows Explorer, there are still 2 other (and actually, more recommended) options that you have: (1) Switching the M240 to MSC mode and formatting in "Disk Management". You can get to this window by right-clicking the "My Computer" icon and selecting "Manage". Make sure that you use the FAT file system to optimize the 1GB memory (2) Switching the M240 to MTP mode and formatting the player in Windows Media Player 10 or version 11. The mode of the M240 can be changed by accessing the menu and going to "Settings", then choosing "USB" In general, formatting the player in "Disk Management" is more effective than formatting it in Windows Explorer. Also, it would be a good idea to upgrade the player's firmware to the latest version via the SanDisk website: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 I hope this helps. The M240 is a great player.
Apr 20, 2007 | SanDisk Sansa m240 MP3 Player
Can't delete files off of my sandisk m240
I can help with the reset problem. You have to format your player by right clicking on the Sansa icon. This will erase all your files, so back them up if you wish to keep them. The folder stucture on the Sansa is not very logical and I still haven't figured it out. I have had my player almost 2 months now. hope this helps. J
Jan 17, 2007 | SanDisk Sansa m240 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
132 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
