Question about IBM ThinkPad T42 Notebook
Laptop screen gone dark
The sxga screen on my T42 has gone dark - the backlight has gone. Can this be fixed?
  • kenstroud Mar 26, 2009
    The screen on my T42p keeps going black. If you squeeze it by the mousepad it will come back on. At first it was rare and became more often. Now it is bad and almost unusable, sometimes just goes black, sometimes it locks up and have to shut it down. Any ideas?
I had a similar problem on my Fujitsu-Siemens Lifebook C-1020 and I had to replace both the C/C inverter that the CCFL lamp. Easy to find/replace the inverter (only take care of input/output plugs), tricky to find/replace the CCFL lamp (because of diameter, lenght and toxic Hg content).
Zpp
Have fun!
Posted on Mar 09, 2008
How to hook up another monitor to t42 2373 window 7 ultimate?
I take it you have changed your graphic cards settings? updated drivers?
Apr 09, 2014 | IBM 23738ZU ThinkPad T42 2373 - Pentium M...
IBM thinkpad t42 with a t42p screen has weird lines all over the screen. I need to be able to fix this! Please.
Would like to ask.......
Did you state ThinkPad T42p LCD screen in a ThinkPad T42?
Same type?
XGA to XGA, or SXGA to SXGA, or UXGA to UXGA?
Did you use the screen Inverter out of the T42p?
An LCD screen, and a screen Inverter are a Matched unit.
Post back in a Comment.
Moving on..........
Diagnose:
Problem can be;
1) Graphics chipset
2) Video Cable
3) Screen Inverter
4) LCD screen
I will detail a diagnostic flowchart, along with my input; after the question above has been answered.
No use detailing it out if;
One: YOU are the one who replaced the LCD screen.
You already know the disassembly procedures, and this will greatly shorten the flowchart I would have stated.
Two: It\'s the wrong LCD screen, or the wrong screen Inverter is being used.
Awaiting reply, please post in a Comment.
Regards,
joecoolvette
Mar 10, 2013 | Computers & Internet
T42p display lights for a couple of minutes through startup then goes dark
But fan still runs, and it sounds like the harddrive is spinning?
Diagnose.
Do you have a VGA monitor available?
You can use a CRT type, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, connect the VGA monitor cable to the left side of the ThinkPad T42. (DisplayPort)
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default, the display should show on the external VGA monitor.
If not;
There are at least three display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY.
Press, and hold down on the Fn key, and at the same time tap once on the F7 key. The F7 key is the Display Toggle-Over key.
3) Good display on external monitor?
Problem is the video cable, or inside the Display Assembly.
Since the display goes dark after a couple of minutes, I can tell you the problem is the screen Inverter, or Backlight.
(Inside the Display Assembly)
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED's.
(Light Emitting Diode)
The Lenovo ThinkPad T42 series of Notebook PC's, uses a single CCFL for a Backlight,
http://www.screentekinc.com/IBM__ThinkPad__T42-series-laptops-lcd-screens.shtml
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter converts the power from the laptop, for the LCD screen, and Backlight.
(Older versions of backlighting that used a series of LED's, used a screen Inverter. Newer versions do not. For these replace the LCD screen)
A screen Inverter and an LCD screen are a MATCHED unit. Make sure you get the correct screen Inverter, or LCD screen, when buying.
Primer over.
One example of a screen Inverter for the T42's,
http://battery-adapter.com/product_info.php/products_id/3381/vThinkpad+T42
Pictorial guide for replacing a screen Inverter, in a ThinkPad T42 series of Notebook PC,
http://www.insidemylaptop.com/replace-screen-inverter-in-ibm-thinkpad-t40-t40p-t41-t41p-t42-t42p-laptops/
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Lenovo Support link to the Hardware Maintenance Manual, for the ThinkPad T42 series of Notebook PC's,
(HMM. It is a Service Manual),
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Click on the bold black subheading -
Hardware maintenance manuals
Then click on the blue -> [+] Click for files
It is a PDF file.
It may take up to 30 seconds before the first page comes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 29, 2012 | Lenovo ThinkPad T42 Notebook
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Laptop screen has become very dark
Check the top of the laptop for a limit switch that shuts the backlight off on the screen when you close the lid. It may be stuck.
Use a paperclip or something to move it.
If the switch appears good - the LCD backlight has failed. The remedy, unfortunately, is a new LCD display panel.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | Acer Aspire 5315 Notebook
My ibm t42 screen goes dark shortly after bootin up
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 10, 2009 | Computers & Internet
Screen keeps going black, and sometimes computer restarts
  • Picture flickering with dim display.
May 03, 2009 | IBM ThinkPad T42 Notebook
IBM t42 Display problem
Sometimes there are keys are your laptop that adjust your settings.
If you know which keys you can hit the fn key simultaneously.
If your not sure go on line and you should be able to find a site that will tell you how to adjust your screen.
In search type your laptop model then type display settings
Jan 12, 2009 | IBM ThinkPad T42 Notebook
Laptop gone dark
This sounds like a burned out backlight lamp.  Had that happen to a Mac laptop used at work:  all the boot-up LEDs and sounds occurred, but a dark screen.  It was fixed promptly by our computer guy, who is pretty amazing at fixing computers.  So all I can tell you is that it shouldn't be a particularly expensive repair.
Jun 09, 2008 | Recoton Advent Advent Q2035A 20" TV
IBM ThinkPad T42 Notebook Logo
385 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
