Question about Vacuums
Tv well it wont go back to number 6 which is the output for the direct tv hd box.There are 7 total outputs and it only letting me get to 0,7 every thing in between it wont let me get to.
    President:
  • 1,673 Answers
Did you try unplugging you box from the a/c power. If that doesn't work, then you should call Direct TV, they need to reset your box.
Posted on Mar 13, 2008
Can I buy a charger?
You need to get the make, model number and check online for local parts distributor or contact the Manufacturer direct. If you cant get one, check what voltage is on its input and output. There may be a specialist electronics store that has a "generic" charger which will work.
Jul 01, 2015 | Vacuums
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Hi My hoover keeps cutting out and then wont switch back on, I have just left it for over a month and it has started working again only to do the same, I have taken it apart and cleaned it as much as i...
Sorry to hear you're having difficulties with your DC14. Like most Dyson cleaners, your DC14 is equipped with a safety device which shuts off the cleaner if it starts to overheat. This is often due to a blockage, or because the filters need a wash. The easiest way to check for and remove any blockages is to follow the steps shown in our online guide:
http://www.dyson.co.uk/support/help.asp?article=626&product=DC14-ANIMAL
The correct way to wash the filter is shown in the video linked below. The filter should be washed in cold water at least once every 3-6 months. Always ensure it's totally dry before replacing it.
http://www.dyson.co.uk/support/help.asp?article=1942&product=DC14-ANIMAL
Hopefully this should resolve your issue. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. One of our experts will be happy to run through some troubleshooting over the phone with you and recommend the best course of action.
Kind regards,
Jack
Dyson Online Customer Support
Aug 16, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hi, I have the Dehumidifey in the boat and have connected a pipe to the back so it draind continually out . The problem is that it still fills up the container and doesnt drain out the pipe. I cannot find...
Pipe or hose must be totally sealed to dehumidifiers output. Then make gravity work... all pipe runs must be downhill, or else it will back up and come out the dehumidifier.
Jun 18, 2011 | Vacuums
Wont charge
Probably the battery pack is worn out or has a "memory" problem. A worn out pack will have one or more cells shorted internally (one or more cells read 0 Volts, and an ohmmeter reads less than 1 Ohm when connected to the 0 Volt cell). If it is a memory problem, it is possible to recondition it, but not simple. You have to remove the pack, then connect a 150 Ohm resistor across each cell and let the battery sit until the cells are completely discharged. You can't just connect a resistor across the entire battery pack because the stronger cells will reverse-charge the weaker ones, which will cause them to short out.
Running the battery too far down will cause the reverse-charge problem, but not running it down at least occasionally will cause the memory problem. (Memory problem explained: the cadmium crystals grow when the battery is charged and shrink as it is discharged. However, the larger ones tend to remain intact on discharge and grow faster than the smaller ones. Eventually they block the ion flow through the battery, so the battery loses capacity. It's called a memory effect because the battery only "remembers" it has the capacity to go down as far as it is habitually used. Running the cell all the way down dissolves the over-sized crystals.)
It is possible you have a problem with the charger. Check for voltage on the charger plug. It should be about the rated output voltage printed on the charger box before messing with the battery.
Apr 23, 2011 | Dirt Devil BD20035 Bagless Stick Vacuum
Hi, I have Microtek 810 Inverter, it is charging properly, problem starts when mains goes off and inverter is in Battery mode, then output of inverter shows no voltage, even i conected multimeter to...
Good day!
You have to do is:
Check the battery if it is leak.Use a voltmeter to test the output voltage of the battery.If your battery had a low supply voltage even you charge it for 3 hours and above.Replace the battery immediately.
Thank you and good luck.
Apr 21, 2011 | Vacuums
I have a Ferguson step down transformer that takes input as 240V and outputs 115v The model is : TS 115/2000EC I need the wiring diagram for the output side
If it is 240 to 120/115, there should be two high side wires and two low side wires and ground wires, isn't that true?
Please post back, thanks.
Gary
Mar 20, 2011 | Vacuums
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Roomba Discovery series wont charge
You should check the dock if there is an output voltage at the charging terminals.
Jan 02, 2018 | iRobot Roomba Discovery SE Bagless Robotic...
Battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Dec 28, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
