Question about Mitsubishi WS-48513 48" Rear Projection Television
Mitsubishi WS48515 press power flashes for four seconds/won't power on
My T.V. won't power on!! I was watching tv,switching channels and it shut
off. I am using an over the air antenna for HD so it was in the middle of switching between standard def to HD. Anyway, after reading these posts I check for codes.. if I am reading correctly it has a code 2. I has 2 quick flashes,pause and 2 quick flashes. Thanks in advance !!!
    Genius:
  • 1,153 Answers
A 2.2 is a Short protect this could be a convergence problem. First check Fuses F9A04 and 05 if these are open then it's the convergence board
Posted on Mar 19, 2008
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I can turn on my haier tv with a dish network remote.I need a code for it when it off from the buton I can not turn it back on with the button
Hello! I recommend that you try a programming method called a Power Scan this will allow you to search for a code and try the functions as you go. If you only receive partial functionality please repeat steps 2 and 3 until you find the code that works. If there is no functional code the TV button will flash rapidly.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Jun 05, 2011 | Haier HL32D1 32 in. TV
I need my codes for Mitsubishi tv so i can program my philips universal PM335 large button remote
Hello
Three digit universal remote codes for Mitsubishi are
004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
Four digit universal remote codes for Mitsubishi are
0005 0151 0051 0004 0009 0254 0022 0141 0180
There are two ways for direct entry.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
1. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
2. Press and release the desired mode button (TV,
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
indicator flashes.
Note: If some buttons do not operate your equipment,
NB: Switch OFF and switch ON your TV with its front panel power on/off button each time before trying an other code.
OK.
Feb 12, 2011 | Televison & Video
Where do i find the code to program a remote for my tv?
Hello
Four digit codes for Mitsubishi are
Three digit codes for Mitsubishi are
002 102 206 502 510 619 709 803 814 914
Direct Code Entry
NB: Switch OFF and switch ON your TV, with its front panel power control main switch each time before trying an other code. OK.
Feb 11, 2011 | Mitsubishi WS-55513 55" Rear Projection...
I need to program my remote, it is a ge universal and my mitsubishi is model cs-40505
Hello
Three digit universal remote codes for Mitsubihsi are:-
Four digit universal remote code for Mitsubishi are:-
Switch OFF and ON your TV with its front panel power switch, [NOT BY THE REMOTE HANSET] before trying each code
Proceedings
Direct Code Entry
OK.
Dec 19, 2010 | Mitsubishi CS-40505 TV
How do you retieve the error codes?
All Mitsubishi DLP Televisions have a built in Diagnostic Decoder to store the last fault in memory. This will help the Mitsubishi Technician determine what area or part defect could exsist due to your television not coming on or turning off by itself. In order to read the error code from the front panel lights, you need to know how to access this information if it is available.
Please remember not to unplug the tv from the power outlet because this will reset the error code. The television must be in the power off state or shut off state to retreive the code.
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check.
Pressing the front panel “ACTIVITY” and “CHANNEL DOWN v” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no
problem has occurred since the last usage.
Note: The front panel buttons must be used, NOT those on the Remote Control. • The number of flashes indicates the value of the MSD (tens digit) of the Error Code. • The flashing then pauses for approximately 1/2 second. • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. • The Error Code is repeated a total of 5 times.
Example: If the Error Code is “23”, the LED will flash two times, pause, and then flash three times, then this will repeat itself for four more times before the blinking stops. If you forget the code, you can start all over again after the LEDs have stopped blinking. Just remember you are looking for a two digit code, denoted by a pause in the middle.
Example: You are watching Television and after 20 seconds it shuts off with no picture or sound. By pressing on the front panel the INPUT and MENU at the same time starts the Diagnostic Procedure, and the TIMER LED will then blink six times, and then a small pause, then six more times. This is an error code of 66, and will indicate to the Technician a defect in the lamp ignition circuitry. This will help us to order parts for the repairs without guess work.
In addition to the above code retrieval procedure- most new Mitsubishi LCD & DLP televisions have a built in Error Code Log or menu system. To access this feature the television has to be on and have a picture or blue screen to read this fault menu . To read this Error Log in the television you have to use the Mitsubishi remote control and follow this procedure: Press & release the Menu button, followed by 3564 on the remote control. You will see Lamp time, Code & Status. If an error has happened, please read the numbers indicated under Code to our service person or office staff. We can determine by these codes how to handle service on your unit.
Jun 03, 2010 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi 50 real projection blue screen
Turners are Bad Signal Board Call Encompass Parts 1-800-638-3328 or your nearest Repair Shop.
Dec 31, 2009 | Televison & Video
WS48515
You lost the 300v line to the tubes that pulls down the brightness. Trace back 300v line to power supply.
Sep 08, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS-48513 48" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
