Question about Canon PIXMA MX310 All-In-One Printer
Connecting Printer My CD drive is not working so is there way to connect the printer by going to add printer on my Mac? When I do this, it asks me for the 'Print Using' but I do not see the printer that matches up.
    Genius:
  • 3,587 Answers
You may need the drivers first..see if they are among those through this link, ok?
Posted on Mar 09, 2008
HOW TO CONFIGURE LASERJET 3055
USB: Run the cd, when its asked for connecting connect the usb cable, do rest..Network. Menu>network setup>TCP/IP>enter IP address>save it.connect network patch cable, take configuration page through printer menu settings, verify the IP address save or not> go to system 1. Run the CD select network as network printer> system will detect the printer go for rest of the process..
2. Through system> start> settings>printers& faxes>add printer wizard > select as local printer> select create new port in dialog box> select TCP/IP> type configured IPadress> do rest of the run process..
Jul 11, 2012 | HP LaserJet 3055 All-In-One Printer
Tip
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when asked this will set up your wireless laptop with the correct printer port based on the Wireless Node Name it will also use the printers inbuilt MAC address. This is standard install and will work for all your Wireless PC's however if you have a Wired (ethernet) PC connected to your Router this process will not work a wireless port will not work with a wired computer.
Follow my 3 steps below to set up standard IP ports for Wired PC's also connected to your Router.
STEP 1: Find your MAC address for the wireless printer (all types of Network Cards will have one so this is no different) this will either be found under the LCD control panel or may even be printer on the bottom of the printer or Print server if it is seperate set this MAC address with an IP address as a reservation in your admin panel of your router 192.168.0.10 in this example.
You can normally enter your Router this using 192.168.0.1 typed in your browser (not the search engine) as all routers are different check here for your make and model http://www.routerpasswords.com if you can't find the MAC address try using ipconfig /all from them command prompt it will be the physical address aka the MAC address
STEP 2:
Install the Printer as a USB printer port by connecting the USB cable to the PC you want the wired printer driver installed on when finished go to the printer driver properties for the driver you have just added, click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install and connect your Ethernet cable from you computers NIC to a spare RJ45 socket on the Router.
STEP 3: To check that the Printer has the correct IP address then test using the tracert OR ping command for the IP address that you have reserved on your router, this is a necessary step otherwise when the lease expires it may take another IP address and your Printer driver will not work unless your printer has the reserved address, it will throw a printer error.
c:ping 192.168.0.10
(this example shows a Standard TCP/IP Port for a Brother DCP-340CW)
Also check in your routers admin panel to see if the Wireless Printer is set up with the correct IP and MAC address, if you still can't find it eliminate your known MAC addresses from all your network cards the one left will be your Printer Server NIC in your Wireless Printer.
If you have setup the incorrect IP and or MAC address you will get this window when you try to add the TCP/IP port
That's it try a test print and you will see it burst into life.... Happy Printing
on Dec 02, 2009 | Office Equipment & Supplies
Need help connecting my printer to my computerWhat's your problem?
turn off your computer. plug in your printer to power. plug the printer cord into printer and then into computer. turn on your computer. if you have the cd that came with it place it into the cd drive once the computer boots up. your computer should detect the new equipment and walk you through the set up wizard. if not go to the control panel and "add hardware" to tell your computer to detect the new equipment which will start the install wizard... good luck!
Apr 02, 2012 | Dell Computers & Internet
I can't get my Canon pixma mp480 to be seen by my computers when it is connected to airport express. Will it work with airport express?
To print using Mac OS X v10.3 or v10.4
  1. Open Printer Setup Utility (located in the Utilities folder in the Applications folder).
  2. Select the printer from the list.
To print using Mac OS X v10.5
  1. Choose System Preferences from the Apple menu and click Print & Fax.
  2. Click Add (+) and select your printer from the list.
  3. Click the Add button.
  1. Install Bonjour for Windows from the CD included with AirPort Express.
  2. If you do not have the CD, download Bonjour from here
  3. Follow the onscreen instructions for connecting your printer.
May 09, 2011 | Computers & Internet
P1005 hp printer windows vista will not recognise
hmmmm i would first make sure all window vista driver are in first. then try installing the cd. or if you want to try the driver only and not all the extra software...
1st uninstall the driver and software and do not connect the printer. until it asks you.
2nd put the factory cd for the printer but do not let it run automatically. cancel the installation.
3 you go to the control panel add printer, etc. have look for the driver and say "have cd" or go to the cd drive where the vista folder is holding the driver file.
i know this can be tidious but its kinda old school for installing a driver instead of letting the cd do it automatically have the computer find the driver on the cd first. dont add all the extra software. try it and see if it works then try to add all the extra software.
personaly i think sometimes the vista updates stuff where it screws with the drivers and then your computer does not know what its looking for. i hope this kinda helps. sorry for your mishap.
have you also tried connecting to all the usb slots?
Apr 21, 2010 | HP LASERJET P1005 Printer
How come my printer icon is not in the corner of my start menu? (like by the clock and the battery level and other small icons in the right corner) I cannot get my printer to print whatsoever.
if the printer is not added then print will not work.
1st you need to add the printer to your system
go to
Start / Printers and Faxes / add printers on the left panel and add the printer of yours.) if already configured
Ensure that the printer is connected and switched on
Else...
if the system asks for the driver then insert the CD of the printer in the CD drive and let the printer be configured.
all the best...pls leave a feedback fro this solution...else let me know...
Thks and regards
Kris Suresh
www.sureshayyar.110mb.com
Mar 16, 2010 | HP DeskJet F4280 All In One Printer InkJet
Connecting from a Mac via wireless print server
Dissconnect USB cable add ethenet cable find printer on Mac set to default should work fine then worry about the wireless side inkypete
Apr 21, 2009 | HP OfficeJet 6310 All-in-One Printer...
Samsung ML-2510 will not print from MAC OS on Macbook
Hi, sorry to hear you are having problems,
OK, first of all, you can stop worrying about solution #3, this printer is a USB or Parallel, there is no networking on this printer so no possibility of an AppleTalk connection.
You say you have downloaded the latest version of the driver from the Samsung website.
And, the Mac is connected DIRECTLY to the printer via USB.... ( It won't work if it's connected to a PC and then shared.. well it might work but I have not been able to make this kind of connection work...)
Well, if this is the case and you are unable to print while the PC prints fine, I expect that it is over the Parallel port or do you plug and un-plug between the Mac and PC...
It might be that the printer needs to reset after switching between the Mac and the PC, Shut off the Printer, I mean really, shut it down, unplug it for 30 seconds then connect it to the Mac and restart the Mac and start up the printer....
If it still does not work, do you have another Mac you can connect to for testing?
Also, the first test should not be FireFox, open the Text Edit app and type ( TEST ) and just print that...
Give that a whirl..
Dec 22, 2008 | Samsung ML-2510 Laser Printer
I need to install my printer to my computer but i don can
Try this. Before connecting the printer put the printer driver cd in the drive and install the drivers. If not asked to connect the printer, then restart the computer with the CD in the drive Connect the printer. Printer will be detected.
Dec 17, 2008 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
18 people viewed this question
old marine
old marine
