Question about LG DLE5977 Electric Dryer
Should we use fabric sheets in an LG electris dryer?
  • 625 Answers
Why not? or use a fabric softener in the washer.
Posted on Mar 09, 2008
Lg sensor dryer is set at 44 minutes but timer drops and does not dry for 44 minutes
The sensor is sensing that the load is done. Even if it is not completely dried. The two sensor bars inside your dryer on the filter system(stick your head in the dryer and look down-you will see them) are most likely lightly coated with dryer sheet fabric softener film. Interferes with sensor. Clean with googone or alcohol. Or just use timed drying.
Apr 12, 2017 | LG Dryers
How can I clean the plate of my Oliso pro. It has wonder under on it
get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Can you use a fabric softener sheet in an LG High Efficency Dryer?
Yes you can. I have an HE dryer and use them 50% of the time for drying clothes. You will have no problems.
Jan 01, 2011 | Dryers
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Fabric Softener
Yes but tie them in a knot.
They can slip past the filter.
Jan 17, 2010 | LG D2051 Dryer
Is it ok to use fabric softener sheets with the
Use the liquid. The sheets will clog up any exhaust pipe or other parts in the dryer. If you live where you vent through the roof, definitely don't use the fabric sheets.
Jun 24, 2009 | Samsung Dryers
Gum melted onto dryer drum
Wet a dryer fabric softener sheet with water; place sheet over gum, wait a few minutes and then gum should be easy to wipe 'up'.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
"cooling" display won't turn off causing heating problems.
Try cleaning off the two curved metal bars (about 4 inches long) on the inside near the lint filter. They are what senses the moisture on automatic dry. When you use fabric softener sheets, the stuff from the fabric softener sheets can coat the bars, which makes the dryer think the clothes are already dry, and puts the dryer into cool down. (using time dry will also take the moisture sensor out of the cycle, if you'd like) This should be a Fix-Ya for your problem.
Dec 15, 2008 | Dryers
LG DLE5977 Electric Dryer Logo
149 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
