Question about Samsung SGH-D900 Cellular Phone
Cant get SGH-G600 connected
I've started installing the PC studio, and I'm at the stage where it asks you to connect the phone by USB cable. ive done everything it asks, yet every time the connection fails!
help please! my new samsung sgh-g600 pc connection worked initially, I downloaded some music from itunes, etc, now it doesn't recognize my usb connection. I've only had the phone a week and have tried reinstalling the software many times.Samsung doesn't support their phones unless brand new. Any advice would be appreciated. Thank you
    Brigadier General:
  • 3,614 Answers
When this happens, click Start and Control Panel. If you are in Category View, click Performance And Maintenance and then System. If you are using Classical View, double-click the System icon.
In the System Properties dialog box, click the Hardware tab and the Device Manager button. Next, look through the list of devices until you see Universal Serial Bus Controllers and click the plus (+) sign next to it. Double-click one of the USB Root Hub lines and click the Power Management tab in the USB Root Hub Properties dialog box. Click the Allow The Computer To Turn Off This Device To Save Power checkbox so it is unchecked. Click OK and restart your computer.
Posted on Mar 09, 2008
  • micromaster
    micromaster Mar 09, 2008
    another way/s:
    1. In Idle mode, press
    <Menu> and select
    Settings
    Phone
    settings
    USB settings
    Media player.
    2. Connect your phone and PC
    with an optional PC data
    cable.
    3. Select Sync digital media
    files to this device
    when a
    pop-up window appears on
    your PC.
    4. Enter the name of your
    phone and click Finish.
    5. Select and drag the music
    files you want to the sync
    list.
    6. Click Start Sync.
    7. When synchronisation is
    finished, disconnect the
    phone from the PC.
  • micromaster
    NOTA:!
    • Do not remove the memory card from the
    phone or unplug the PC data cable while
    synchronising. It can cause data loss or errors
    in the music playlist.
    • If you use the phone to format the memory
    card, all licenses and WM DRM files will be
    erased.
  • 316 Answers
SOURCE: samsung sgh g600 security codes
security code is normally 000000 unless changed by someone else
Posted on Nov 22, 2007
technofrenzy
  • 56 Answers
SOURCE: pc studio for samsung SGH-G600
Hi there. You can download it from http://za.samsungmobile.com/supports/softwaremanuals/pcStudio31.do and choose the one for vista
Posted on Aug 11, 2008
devdeep dhar
  • 375 Answers
SOURCE: i need unlock code for samsungsgh g600
Sir, You can get it in the manual of the phone. It is supplied there. If not, contact the dealer. They will give it to you.
Posted on Sep 20, 2009
  • 83 Answers
SOURCE: i cant connect to the pc studio 3 using my sgh
You did not indicate the option you tried using. Try all the connection options: USB, Bluetooth, infra red etc. If it does not, your might be having problem with the configuration of the pc studio.
Posted on Oct 30, 2009
Buland Khan
  • 297 Answers
SOURCE: problem in my sgh-g600
plz....first try to reset ur phone...i hope i will work
Posted on Nov 14, 2009
My samsung phone is not connecting through data cable with my pc. i bought a new samsung set of beat addition 2 days before for using internet through data cable. but my phone is not connecting with my pc...
run again your pc studio cd software installer..
by default, it will play and give the swf home page where there is an option for install usb driver. select install usb driver in order to install your usb driver but before installation disconnect your phone from pc and remove the usb cable. once it's installed, right click your PC studio and select open automatically when device is connected.
>>on your phone, select settings,select settings for your pc connections, check ask for connections and reconnect your phone.
Feb 21, 2010 | Samsung Beat SGH-T539 Cellular Phone
I cant connect to the pc studio 3 using my sgh g600 samsung
Oct 30, 2009 | Samsung SGH-G600 Cellular Phone
Cant seem to download photos from my phone to my pc.my phone is a g-600 and i have never downloaded pictures from my phone before i have put the ubs cable in and the disc that comes with the phone but...
Disconnec the phone from the PC. insert the Disc and run and install the Samsung PC Studio on the PC. Now reboot the PC. Connect the phone to PC via the USB cable. And the PC should say SGH G600 connected. The with the help of file manager on the Samsung PC Studio, xfer the pics to whatever folder you want.
Sep 15, 2009 | Samsung SGH-G600 Cellular Phone
I can't transfer files using USB connection to a PC... help!
dear,
did u try with the other cable.
if yes, then reinstall the usb driver for the phone and then try with pc suite or if u didnt install the driver, then u have to install it.
regards,
dont forget to rate it.
Feb 15, 2009 | Samsung SGH-G600 Cellular Phone
My samsung G600 wont connect to my pc studio 3 on computer?
If you are using pc studio you must first check that it is set to use it.Try this first:-
1,settings-phones settings-USB settings-pc studio.
2,If not then check that your pc USB's are switched on.
Aug 25, 2008 | Samsung SGH-G600 Cellular Phone
Samsung SGH-G600 connection to pc studio3
Try this, I had a the same problem as you guys + found this on a web forum. Quite a frustrating problem to have, It fixes the phone, but after a while you have to do this over again. I am wishing I never bought this phone, even though the reviews were really great.
Unplug usb cable from phone
Type *#52828378# into phone
this comes up
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
select 3 serial test
this comes up
1 PPP UP
2 Serial download
3 Run TCK
Select 2 Serial download
Phone will reboot.
Once rebooted, connect usb cable and pc studio will now work.
Aug 06, 2008 | Samsung SGH-D900 Cellular Phone
hi i have the same fone wen u have installed ur pc suite click on it go to file an go to connet click on it make sure ur usb is in the fone an pc an it shud work remember fixya at the end ov ur solution thankyou
Jan 09, 2008 | Samsung SGH-D900 Cellular Phone
SAMSUNG SGH G600
have you tried  pluging into another spare usb slot on pc .also have you done any updates for the pc studio software recently.
http://uk.samsungmobile.com/wcms/products/phones/phonedata/download/UK-SGH-G600.jsp
riz.
Oct 16, 2007 | Samsung SGH-D900 Cellular Phone
Cannot get PC Studio 3 to work properly
Ok.... found this on another forum, tried it and it works! Fixed my problem, which was exactly the same as yours. Unplug usb cable from phone Type *#52828378# into phone and this comes up 1 Trace setting 2 OTA type setting 3 Serial test 4 TFS reset select 3 serial test and this comes up 1 PPP UP 2 Serial download 3 Run TCK Select 2 Serial download The phone will reboot and once its rebooted connect usb cable and pc studio will work.
Oct 04, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
106 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
