Question about LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB
Lacie 1TB external hd won't mount!
Lacie 1TB Exteral won't mount, the light flashes but it will not appear on my desktop. Please help!
I'm using a Mac Pro and the drive is being used as a scratch disk for Final Cut Pro.
  • 3 more comments
  • robnambodia Mar 09, 2008
    Thanx for getting back to me so far. I have been using it without incident for a year, and I have checked and rechecked the wires. I also replaced the power cable and the firewire 800 cable, then tried it with firewire 400 instead. The light continues to flash. If I shut down and start up my computer 5 or 6 times it seems to mount, but not all the time. Any clues?
    Nope, still running 10.4.11, and I have another identical lacie drive that has no problems at all. So far...
  • chani799 Sep 09, 2008
    I just bought a new LaCie Big Disk Extreme + and about two weeks ago I loaded hours of footage via Final Cut Pro onto the drive. My FCP Project is on it as well. I am using a Macbook Pro with the lastest OX.5.
    I just hooked it back up this morning and it just won't mount. Disk Utility does not see it, but when I check the System Profiler, it sees the drive mounted via firewire (the current cable connected).
    The power is on, but none of the cables (USB, Firewire 400 and 800) make a difference. Any troubleshooting advice out there?
    Thanks a million!
    CAB
  • skywise Sep 25, 2008
    My big disk extreme (1TB ) didn't show up last night- I've had it since the end of july, and it's worked like a charm for automatic backups, until last night around 10pm.
    this morning it was not mounted on my computer at all- no difference in plugging it directly into the computer vs into another drive.   I'm connected via FW 800..
    I have an imac, 24 inch 2.8ghz, 4GB ram, 1TB hd
  • Anonymous Oct 22, 2008
    I pretty much leav it running because every other time I reboot, it won't mount :(
    Genius:
  • 3,587 Answers
Check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Posted on Mar 09, 2008
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    which o/s you using on that MacPro? recent upgrade by chance?
  • Patrick Michaels
    hmmm..have you considered swapping the drive, and the cables, to eliminate those connection devices as a potential issue? Just use the cables that work with one drive, to test the cranky one.
    thanks for using fixya
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Mac OS X 10.4.11 SimpleDrive 1TB HD appears on Desktop only occasionally. Does not appear in Disk Utility. Have transferred files to it, light is on, plugged in, just takes several restarts to appear.
If you unplug the power and USB cables from the drive (but not the computer), plug in the power and then plug in the drive, the Mac will remount the drive on the desktop. I am having the same issue, only my old HDD used to be my TimeMachine drive and now I want my SimpleTech drive for that. The issue is that when the SimpleTech drive disappears, OS X automatically uses my old HDD for TimeMachine and all my disk space vanishes.
Very ARRGH!!!
I'm trying to find a better solution, because having to mess with the cables means it's no good for TimeMachine... and very frustrating on top of it.
Aug 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Lacie 1TB External Drive flashing blue light, not being found
Hey
I know this arent a solution
Tho I have the same problem atm, this is just a networkstorage device, and this is a newly 1.
Feb 04, 2009 | LaCie d2 Extreme 250GB External with...
LaCie HD won't show up on Mac desktop, quit showing up yesterday
Hello! Had the same problem - go onto the Lacie official website. Select whatever type of drive that it is you have, and simply go onto the software update page. I literally downloaded the desktop manager (I own the Sam Hecht Little Disk) and it appeared! Good luck
Nov 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB Logo
2,037 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
