Question about Cameras
I bought a Sunpak 383 external flash. When I put it in the hot shoe, the menu in my camera doesn't allow me to access the external flash options. I don't understand how to use the flash
  • 66 Answers
Sunpak 383 is not a 'dedicated' flash that is why it don't give any information to the camera.However set the camera in manual mode and set the aperture and shutter speeds and match the iso of both and it will work like a champion.
Posted on Feb 24, 2010
Genius cam nb 100
Posted on Mar 09, 2008
How to put on a camera
If the camera is designed for an external flash then it will have something called a "hot shoe"
Google "hot shoe" and switch ti images to see what a hot shoe looks like.
Aug 13, 2014 | Cameras
Will sunpak 622 flash work with Nikon 5200?
You will need a "Hot shoe to PC connection adapter" to connect the PC sync cord to your camera
Dot Line Nikon Hot Shoe to PC Connection Adapter
Jan 29, 2014 | Sunpak 622 Super Pro TTL Flash
Will a sunpak 544 aoto flash work with a nikon D3000? dont see a way to connect the two
The 544 connects to a camera via the PC cord (in this case "PC" has nothing to do with personal computers). The D3000 doesn't have a PC port, so you have to use something like the AS-15. The AS-15 mounts onto the hot shoe on top of the camera and provides a PC port.
Mar 08, 2013 | Sunpak Auto 544 Flash
My camera don't want to make photos with the flash. I activate it from menu, i opened it manually and the picture is without flash. Why?
The camera does not flash. Solution
sp.gif sp.gif Follow this procedure to troubleshoot the camera not flashing.
  1. Select the correct flash mode . NOTE: When set to the Forced Flash setting, the camera should flash for all still pictures.
  2. Perform a reset procedure .
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada United States Products
sp.gif sp.gif DSCF828 Last Modified Date: 03-04-2010sp.gifID: C322716 document.write(""); ---
How to troubleshoot an external flash that will not work. Solution
sp.gif sp.gif IMPORTANT: Depending on the mode of the camera, the external flash may not be available. Refer to the instruction manual of the camera for more information.
  1. Ensure the external flash is properly inserted into the accessory shoe on the camera.
  2. If using the connection cord, ensure it is properly attached.
  3. If the external flash uses batteries, ensure fresh batteries are installed.
  4. Ensure that the POWER switch on the external flash is set to ON .
  5. Ensure the hot shoe setting on the camera is properly set for the type of external flash and camera being used. NOTES:
    • When using a commercially available standard external flash, ensure the hot shoe is turned on.
    • If a Sony external flash is being used with an advanced hot shoe on a Sony camera, ensure the hot shoe is turned off.
    • It may be necessary to refer to the instruction manual of the camera and external flash for specific information about the hot shoe.
  6. Ensure the READY lamp on the external flash is illuminated.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Mavica Last Modified Date: 03-04-2010sp.gifID: C292057 document.write("");
Jul 23, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Sunpack Compatibilty
ifyour nikon has a hotshoe it should work quite well. I use sunpak flash on both canon and olympus without any problems. Just connect to hotshoe and shoot.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Sunpak 383 Super Flash
I have sunpak pf30x fash unit for canon camera.but i need to use it for nikon D90.how can i do it? is ther any converter units or hot shoe unit
No. The PF30X is a dedicated unit, specifically for the particular brand of camera. A Canon unit, such as the one you have, will not work in auto mode on a Nikon camera.
Apr 25, 2010 | Sunpak PF30X for Canon Flash
My Sunpak Auto 383 Super will not fire on or off the camera. When I turn on the switch, the ready/test light lights immediately. I suspect the bulb is burned out, so I wonder if that can be replaced.
There can be one of many parts which is gone :
Flash tube,capacitor,trigger cap.or triggering switch.
Warning as it has 330 volts even when battery is removed do not open if you are not aware of the risks.
Sunpak 383 contains no bulbs inside.
Feb 21, 2010 | Sunpak 383 Super Flash
Sunpak 383 problem
Try to trigger it by shorting Center of shoe mount and the side terminal with a small wire.If it is firing the flash is ok.
If not there is open connection in the sync jack ,due to repeated inserting of sync chord.The springy part inside is not going back to its normal position.
You can fix it your self by opening it(adapter only)
.If you are new to this take a photo of the wiring immediately after opening the shoe adapter to see the position if any wire breaks later on.
Do not give up .383 is great flash
Nov 05, 2008 | Sunpak 383 Super Flash
Sunpak Auto zoom 3000 thyristor
You can use the Sunpak on a bracket with a "slave trigger" and fire the slave with the Nikon's pop-up flash. I do the same with a SunPak 3600 Auto Zoom. Just remember not to have the red-eye feature operating. Those little slave triggers are only a couple of dollars and I already had few brackets.
Jun 03, 2008 | Cameras
602Z Flash
Well she is right in one way and wrong in another. The Fuji 602 does not have flashes that it will work TTL metering with. This is due to the single design posted on the hotshoe. But the big advantage with the 602 was its ablility to handle about anyflash you pop on it. It has been unoffically released many times, but most say the 602 can handle a trigger voltage of 500. Which is WAY more than most (5-8). There are alot of good flashes and manufactures that are out there, and with a quick search you will find MANY... Just stay below 500, actually 100 to be on the safe size and you will be ok. You stated it would not fire? Did you go into you menu system and set it for external flash? Its all way over on the left side, i think the first option. Other than that, you should be good to go. Good camera, hope you enjoy it.
Sep 04, 2005 | Fuji MX-600 Digital Camera
Cameras Logo
120 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
