The parental code is on, but I didn't set it and I have no idea of what the code is to turn it off, so we can't use our DVD player.
Is the display showing 'LOCK'? If yes you have to press 'STOP' for about 3 seconds to UNLOCK it.
Posted on Mar 09, 2008
  • 79 Answers
SOURCE: parental block princess dvd
This will make the player region free which may also reveal a menue that either gives you the oppertunity to clear the password or clears it automatically...
1. Turn on the Player (with no discs in)
2. Press the Open/Close button (leave it open, like if you were yet to insert a
DVD)
3. Press the Display button (on the bottom of your remote control, close to the
numbers 0-9)
4. Press the following sequence: 1,3,6,9.
5. Press the number of the Region you want (0 for Region free)
6. Turn off and on your player.
Posted on Dec 12, 2007
SOURCE: How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Posted on Feb 22, 2008
SOURCE: parental code
with no disc in the player go to set up and go to change password i think the default is 99999 then you can change it to something you remember or keep it the same if you so choose. i would give that a try
Posted on Mar 01, 2008
SOURCE: disney dvd player parental control code
1234 worked for me
Posted on Mar 03, 2008
SOURCE: JVC XV-M555 DVD player has the parental control
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Posted on Jan 02, 2010
My sony dvd player will not play a new dvd, it says parental codes are on. How do I turn off the parental thing?
turn on your DVD & TV. Press Menu for DVD. Look for Settings. Should be in there. May need a password....
Jan 13, 2012 | Sony Televison & Video
My Memorex 2040 dvd player gives "error parental" when I try to play a dvd. Any idea what this is or how to fix?
The Parental controls for your DVD player has been turned on. The default setting for most Parental Control setup is G rating meaning that anything above a G rating will not play unless the override code is entered. I was unable to locate a copy of your manual, but if you look in your copy for a heading called Parental Controls, it should explain to you what has to be done to either change the rating or remove the control altogether. Unless you have small children that may use your player you can probably remove the controls altogether. Normally you would have to go into your Setup menu, and then look for Parental Controls in that menu. Unless someone setup a code, you should be able to go in and just turn it off. If there has been a code applied and you are unable to find out what it is you will have to contact Memorex support to find out how to remove it. To ensure that it doesn't get turned back on you might want to hide your remote, as you need to use it to turn the feature on and off.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 16, 2011 | Memorex MVD2040 DVD Player
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
JVC XV-M555 DVD player has the parental control set somehow. Need to know how to disable the parental control on this DVD player
Jan 01, 2010 | JVC XV-M555 Multi-disc DVD Player
Mintek Passwords
I believe the password code is 88888. This is factory set this way and can be changed
Oct 20, 2008 | Mintek DVD-1600 DVD Player
DVD player parent lock
My unlock code is 0123, I didn't set it but it works to unlock parental controls
Mar 28, 2008 | Disney Televison & Video
Parental code
although my situation was a bit different, part of msimeomix's solution still worked. after entering the password "3308," the screen went blank. i knew this parental code had worked but it would still not allow me to access the "setup" or "menu" options. i pressed "STOP" and then ejected the disc/turned the DVD player off. upon turning it back on and entering the password "3308" i was able to immediately press "PLAY" and it worked. enjoy the movie :]
Mar 23, 2008 | Daewoo DV-6T955B DVD Player/VCR
Zenith dvb410 parental control
Without the DVD in the player go into your setup menu. Arrow down to the icon that is a lock press enter. arrow down to password and if it says new or change select it. you need to enter a pass code so that when the prompt comes up you can override the parental limits.
if you need to clear your old security code because you have forgotten it the manual says to input the 6 digit number from teh setup menu "210499" I did not do this as I had never set up a security code but the Across the universe DVD will play as long as enter the security code.
Feb 15, 2008 | Televison & Video
DVD not playing due to "Parental Lock" being set..
In the back side of your equipment mentioned that the regeion code.please check read the region code and try to play the same region dvd cd's.other cd's not possible to play with out chaging region code.you can contact the nearest service provider to chage the region.
Jan 15, 2008 | Sharp DV-NC55U DVD Player/VCR
Aug 24, 2007 | Zenith DVB412 DVD Player
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
