Question about Toshiba Satellite A105 Notebook
No Operating System found
My computer just went down one day and the message I get in No Operating System Found. Whan I go into my setup it says none next to HD is it possible that the cable is not hooked up all the way or is the HD bad? How can I tell and what does the data cable look like?
  • MrsSims Mar 11, 2008
    Thank you all I will try that, if not take it in.
  • 520 Answers
Remove hd check connections and connector make sure clean from dust ( dust is a conductor ) ;remove battery ,reseat hd ;startup from ext power (dont connect battery yet)
system may find hd now and boot if so replace battery.
if not hd may not be neccessarily be damaged it may have missing sys32drivers.try install new os from cd if system still say no drive(hd) then hd is beyond repair.
Posted on Mar 11, 2008
  • Toshiba Master
  • 13,433 Answers
You can open the harddrive cover to check.
Most likely the drive is broken and needs to be replaced.
Its going to cost you, but take the laptop to a repair service / shop / center.
Thats if you dont have warranty.
You can try reconnecting the harddrive.
But If it already was well connected. Its most likely broken.
Posted on Mar 09, 2008
I have the disc for the american greetings creatacard special edition but it wont down load on my computer what can i do
First, make sure you have a version American Greeting compatible with your operating system. You have Vista Ultimate Edition, but if the software is from, say, Windows 95 it's not going to work.
Second, if your American Greeting is on a CD you usually need only put it in an wait for the setup to start. If it doesn't go to My Computer and double-click on the CDROM (or DVD or whatever) optical drive. That should launch the setup.
Third, if it still doesn't start, look for "setup" in the list of files on the CD and double-click on that.
If none of these start the CD then take the disk to another machine and see if it starts there. If not, you have found the problem. If it does, then it is possible that the CD drive in your system doesn't work properly.
This all assumes that when you say it "wont down load on my computer" you mean it won't run the setup. If it does start but won't load after starting, you will need to provide further information: like does is issue an error message? Does is just sit there for hours on end with the circle spinning? The more you tell us the better we are at figuring out what's wrong.
Sep 14, 2013 | Microsoft Windows Vista Ultimate Edition
When booting the laptop it says PXE-E61: media
When you start your computer, the motherboard searches connected drives for the operating system. The search order is usually the optical (CD/DVD) drive first, possibly a USB drive next, then the hard drive. If none of these work, some systems are set to try booting the operating system over a network cable. What the cryptic message you're getting is telling you is that the system tried a network boot without success, and that maybe the trouble is a bad cable.
This all means that your hard drive isn't being detected, or that there's no longer an operating system on it. It's possible the connector from the hard drive to the motherboard has come loose, which can sometimes happen since laptops get moved around. The hard drive may have gone bad, or there may be a problem with the motherboard that is causing it not to find the hard drive. Or the hardware may all be fine, but something (a virus or other malware, for instance) has deleted files needed to load Windows.
When the computer first starts, you'll see a message about how to enter BIOS setup. The BIOS is the motherboard's built-in program, and through the setup pages you can see what devices it detects. This will let you know if the hard drive is being found. Some boards include diagnostic tests you can run on the hard drive if problems are found. You can also check the boot order; you may find that for some reason the boot order has been changed so that the network boot is being tried first. Strange things can happen to BIOS settings, often a sign that the backup battery for the memory where the settings are stored is getting weak.
If you have access to a Windows XP operating system CD, you can set the BIOS to boot from the CD drive and try using the Recovery Console feature. Information about this can be found at Microsoft's site.
Good luck getting your laptop back up and running quickly. Thanks for using Fixya!
May 29, 2011 | Acer Computers & Internet
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
Operating System Not Found
On my Windows 7 laptop, I have got "Operating System not found" with black screen, to fix problem,Windows Boot Genius helped me finally!
Mar 17, 2009 | HP Computers & Internet
Operating system & harddrive not found
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk? In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free Grisoft Home Page - Spybot S&D Spybot Home page - AdAware Lavasoft Home Page
Basic versions are either free or ask for donations.
Oct 26, 2008 | Gateway 4525GZ Notebook
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
After format - i cant load windows operating system.
hmm..ok...you need to go to setup, and change the boot order to CD then, hard drive, then something else, if you have it..
that should do it.
got backup for your Acer?
Feb 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Compaq presario 1250 laptop
It is possible that while you had it apart you lossened one of the IDE ribbon cables from the motherboard or harddrive.Take it back aprt and make sure all the cables are tightly seated.Rate me FIXYA! if this works!
Nov 18, 2007 | Compaq Presario M2000 Notebook
Toshiba Satellite A105 Notebook Logo
130 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
