Question about Refrigerators
The refridgerator door of my Whirlpool side by side refridgerator/freezer is not closing properly. I checked for any obstructions including possible deterioration of the magnetic strips. It acts like the door may some how be sprung. It feels like resistance when I try to get it to close, but no obstructions. Is it possible to replace fittings or a sprung door?
    President:
  • Refrigerators Master
  • 2,651 Answers
Look closly at bottom of door there is a metal door stop, screwed to bottom of door, that prevents door from opein too far. Well when the door is forced open too far the door stopbends sdn then actually prevents door from closing all the way, you see it hitting the hinge(if indeed this is your issue), to repair it either simply bend it back staight witha pair of pliers, or what i sometimes do is switch the refrig and freezer door stops.They are identical, but only require the use of one side, (1 stop will do either door just depends on position as to how it operates)
Posted on Mar 09, 2008
I have a Whirlpool bottom freezer fridge model WRF560SEYMOO. The bottom drawer will not close completely. we have emptied and turned down to thaw out any possible ice blockage.
check all the shelves,check the bin on the door,sometimes one side is up farther than the other side keeping the door from closing or remove the bin and shelves and see if it closes,one of them are hitting or the tracks on the sides are bad but most likely it will be the bin or shelf.
Feb 04, 2018 | Whirlpool Refrigerators
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Every time I close the refridgerator side the freeze side opens, how do I fix it.
Hello ttd1977 - Often when one door is closed and the other opens, it is because either the hinges are damaged or the refrigerator has a poor door sealed. Trying checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. If the gasket is not sealing properly, it may possibly near replacing. Since there are cost differences in parts it is always a good idea to have a certified technician properly diagnosis your appliance. Thanks for allowing me to help you.
Apr 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer Cold Fridge not cold, vents clear of obstructions. Vent at top left of fridge making a clicking sound, some cold air coming out of vent, probably not enough,Freezer control on 2 ,Fridge control on...
Need to defrost fridge completely for about a day then switch on again. Possibly door was left ajar on freezer, or auger motor iced up due to product being to close to outlet..
Sep 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have a whirlpool side by side fidge. My freezer is not working but the refridgerator is working fine. Everything is melting in the freezer.
Three possibilities depending on the mode number you have. Most likely is the defrost control is defective. Then the other 2 possibilities are the defrost heater and the defrost thermostat. Send your model number and I will be able to tell you just what you have. Thanks, Sea Breeze
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
My Whirlpool side by side is having issues. The refrigerator is not cooling although I have set the settings to 5 (coolest). My freezer is over freezing with big chunks of ice every where. What is the...
Hmmmm, chunks? Are the doors properly aligned? Closing completely? dispenser chute door closed? if so may have frosted the airway to the refrigerator and blocked it. I would totally defrost it and check again.
Jun 11, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
425 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
