Behreinger UltraMeiser Pro Configuration
Need help configuring a behreinger ultrameiser pro.... Anyone into audio? - This is for use on Net Radio.
  • 1,512 Answers
Hi Djlazy
All the manuals are available here. Included as a download is a package of presets that will help you to get the best out of it for net radio. I suggest monitoring your netcasts via the net, and use the device to tweak your send for best results. This is how the monitor audio performance in FM commercial radio even. Good Luck, link me the station when yo get it up :)
regards
Graeme
Posted on Mar 09, 2008
Adobe acrobat x pro configuration error 16
you need to uninstall and re-install before install download it again from main site again it will work.
Jan 19, 2014 | Adobe Acrobat X Pro
On my uniden pro 510e I can transmit but I cant receive all I get back is static got any clues?
Which radio are you referring to, the Pro 510e or the Pro 510xl?
In any event, to transmit and receive clearly depends on your antenna, it's location and it's surroundings and HEIGHT.
Radio waves on these radios depend mainly on line of sight and propagation factors, If you have an indoor antenna, that could be the problem, if it's an outdoor fixture, it needs to be in such a position so that the coax cable isn't being interfered with by another electrical fixture, the Height of the antenna, is most important, the higher, the better, taking in all these factors and a bit of try this and see approach should find a solution to your reception/transmition issues. That's part of the fun of setting up a base radio, experimentation, configuration and the results you want will be worth the effort.
I hope this has been helpful for you.
Cheers, Peter
Jan 29, 2012 | Uniden PRO510XL 40-Channels Base CB Radio
I'm using Autodesk sketchbook Pro 2010 and I frequently get a Micreosoft Visual C++ Runtime Library Error. It reads Runtime Error Program: C:... This application has requested the Runtime to terminate in...
Possibly you may need to reinstall your program. Or you could go into your configuration settings and resetting your configuration to factory standards, then change one thing at a time in the configuration until you find the setting that is causing your operating system to act up.
Mar 29, 2011 | Autodesk SketchBook Pro 2010
My phone is a Samsung Omnia Pro B7320 Windows Mobile 6.1 and I have downloaded Foursquare. Foursquare is downloaded to the phone but the application does not load says This application requires a newer...
Some applications do require a newer version of .NETCF. You see, I have uploaded .NETCF v3.5 for you. I have also uploaded a small application, .Net Configuration. Install both of them on your device, and run '.Net Configuration'. I'll tell you how I configured it on my device, and you decide if it fits your needs: In the 'Device Policy' tab, I selected '3.5.7283' and tapped on 'Apply'. However I know that the mobile calculator doesn't quite like v3.5, for what, in the 'Application Policy' tab, I selected '\Windows\MobileCalculator.exe' , assigned it to '2.0.7045' (my version of the default .NETCF v2;0 - yours might be slightly different) and tapped on 'Apply'. Tapped on 'ok' to leave the application, and restarted my device.
Of course you can do differently: set your 'Device Policy' to v2.0 (as it has ever been) and assign the application, which is issuing errors with v2.0, to v3.5.
Hope it works for you.
Cheers!
Carlos
Jul 03, 2010 | Samsung Omnia Pro B7320 Smartphone
Intel pro/100+minipci config
To get into the BIOS configuration, press the F10 function key as you power up your laptop.
Feb 01, 2009 | Compaq Armada M700 Notebook
Logitech quickcam pro 5000
try to reinstall your quickcam pro
the software is found here:
http://www.logitech.com/index.cfm/435/243&cl=us,en
First you might need to use the add or remove programs to remove the old driver then install the newone
If you need more assistance let me know, I'm here to help
Feb 23, 2008 | Logitech QuickCam Pro 5000 Webcam
57 people viewed this question
 Grubhead
Grubhead
