Question about SanDisk Sansa c140 MP3 Player
Not able o view the contents
Hi i'm using sansa c140 player... when i connect it to the system.. it doesnt apper in MY COMPUTER. but if i connect in MSC mode it shows.. only these folders.."AUDIBLE,RECORD" so on... how to add my songs to it.. how to make it show.. in my computer
  • hmsfan2448 Apr 08, 2008
    same issue
  • Anonymous Jun 01, 2008
    try to open it on my computer
    try to play it didn't play
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
How to download music to sandisk sansa
Please view my FixYa Tip on this subject at this link which covers the common issues.
Many thanks for using FixYa.
Jan 01, 2010 | SanDisk Sansa c140 MP3 Player
How do you take music off your mp3 player
The Sansa c140 can be operated in MSC and MTP mode for transferring and deleting music files.
See also setting USB mode for autodetect or MSC mode on page 16 of the manual: link to the Sansa c100 series manual.
  • For deleting files a connection to a computer has to be made in either MSC or MTP mode, see page 10 of the manual.
MSC mode means that a computer will see the player as a removable disk when connected.
It's like exploring the computer detecting the player as an external memory, showing up as a drive letter with about 1 GB of memory.
Before disconnecting the player, always safely remove hardware, the icon in the bottom taskbar on the right.
MTP mode means that a computer has software installed like Windows Media Player 10 and in this software, when started, the player is being recognized as Sansa c140.
Before disconnecting the player, wait for the message that it is allowed to disconnect the device.
How to use Windows Media Player 10 ? See the site of Microsoft:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa c140 MP3 Player
Sansa c140 shows nothin??
my sansa c140 do not play mp3 music, whats happened?
Nov 09, 2008 | SanDisk Sansa c140 MP3 Player
My Sandisk Sansa C140 only display sandisk logo
You can update the firmware. This will return your device to factory settings and fix any internal errors. All your current content will be deleted.
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
Jan 24, 2008 | SanDisk Sansa c140 MP3 Player
SanDisk sansa c140
You need to Have Windows XP / SP2, Wndows Media Player 10 or higher in order for the device to be recognized. If you have these components, try changing the mode on the device to MSC Mode. Settings>Mode>MSC. Best of Luck.
Sep 11, 2007 | SanDisk Sansa c140 MP3 Player
Sansa c140 won't turn on
Try to connect your Sansa c140 to another PC. If it continued to show that it isn't recognized then I'm sorry to tell you that your Sansa ROM has malfunctioned. Only people at Sandisk could fix it.
Jun 02, 2007 | SanDisk Sansa c140 MP3 Player
Fixing my C140 (has no lettering on screen)
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Jun 01, 2007 | SanDisk Sansa c140 MP3 Player
Sandisk Sansa c140 mp3 player
how cant i transfer music to my scandisk using computer files from my computer/itune library because the library doesnt come up when i plug in the scandisk
Jan 01, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
