Heating & Cooling Logo
Posted on Mar 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have got a red blue black orange and yellow coming from the inside to the outside for the control wires how does it hook up on the goodman heat pump to the wires there! inside it is a blue with pink stripe red orange white blue (inside the heat pump) thanks
Anonymous
Level 3:
  • Master 614 Answers
  • Posted on Mar 17, 2010
Anonymous
Master
Level 3:
Answers
614
Questions
0
Helped
274900
Points
1718
Blue with pink strip hook your Y or Yellow to this. Red to Red Orange to Orange Blue to blue White to black. Rus
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Need help wiring this theromostat. I ahve the following color wires.....Green Red Black Blue White Yellow and Orange. Need to match them to the following connections: G RC RH Y/O W/B Y1
G= Green Wire (Fan) RC= Red Wire (Power Cooling) Y1= Yellow Wire (Cooling Contactor) RH= Black Wire (Power Heating) WB= White Wire (Heating Control) YO= Orange Wire (Damper Control)
Blue Wire is usually to C= Common
I installed a new Honeywell Programable thermostat, When I turned on the AC it turned on the Heater... I followed the wiring but some of it is not making sense... G=Green, Y=Yellow, R=Red, C=Blue,...
Hi, the problem is you have bought the wrong thermostat for the unit if it is not a heat-pump. A heat pump will have W-1, W-2 for heat strips, and Y-2 is for 2nd stage cooling. G is Green for Fan, R is Red for Power, Y is Yellow for cooling, and W would be for Heat. This is all you need if you have gas heat, Orange is for a reversing valve for a heat-pump, and the blue is also for the reversing valve on a Rheem heat-pump. The stat you need will have these terminals, if you are sure its not a heat pump, which I am sure you would know. The stat you need has these terminals. RC and RH. It will have a Red jumper wire connecting the 2 terminals. This is where the Red wire connects, to either one, as they connect together. Connect G to Green, Y to Yellow, and W to white. Since you only have one control transformer, that's why the stat has RH for Red Heating, and RC for Red cooling tied together. Just hook the red coming in to either one. You need only, R, G, Y, and W, to run this unit. Look at your old stat and check the terminals. A heat-pump, uses many more conductors to operate it. O or orange for the reversing valve, blue also depending on the unit. C for common, W1 for stage one heating, W2 for stage 2 heating, Y1 for stage one cooling and Y2 for stage 2 cooling. This stat is used for a commercial unit with multible stages of heat and cooling. If you have a common wire and no batteries on the old stat, go to the indoor unit, remove the panel, and see if you have a common wire hooked up, such as the brown, black, or maybe blue. If so, you will need to hook it up at the stat if it has a C terminal. If it has batteries, just take all of the extra wires and shove them in the wall. You won't need them. Just the R, G, Y, and W, and you will be back on line. Very easy.
Please rate me. Take it back and have them sell you the right stat. Please keep me posted and I will be here if you need my help. Thank you for using Fixya.
Shastalaker7
A/C, and Heating Contractor
Originally installed in 1978 as a heat pump. Threw away the outside unit. Want to use the electric inside furnace/air handler as a shop heating source. I don't know how to wire in the thermostat which...
Red is 24v from transformer to terminal R
Green is to Terminal G for the air handler fan motor
Yellow is to Terminal Y for calling cooling to the compressor and fan outdoor unit
White is to Terminal W for calling the heat trips which are usually sequenced to keep them from all coming on at once and over drawing Amps and kick off breakers.
Orange was for outdoor reversing valve for a heatpump system
Blue or Black is usually used for common or negative continuity in the circuit such as Red wire and Blue/Black wire to power a thermostat features on digital T-stats. If not digital T-stat then no common is needed to hook-up at T-stat
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
3helpful
2answers
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
Need to know what the wiring diagram is for a ar30-1 airconditioner, for a home
Sounds like a Goodman A/C. Wires R red Y yellow cool W white heat Green FAn Blue or brown will be common. O or orange if heat pump goes to orange outside unit.
1helpful
Thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
2answers
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Top Heating & Cooling Experts
Paul Carew
john h
