Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Service Manual Does anyone have a service manual for a built in Kitchen Aid KEMC307KSS, combo microwave oven? I need to switch out fuses or door switches since it displays "DOOR" on the control panel. I replaced the inline 20A fuse and it still displays "DOOR" message.
  • ericjo Mar 27, 2008
  • stef15401 Jun 06, 2008
    I need a service manual too. Why don't they provide these items at Kitchenaide parts. I want to fix my own appliances especially since warranties are expensive and repair men charge over $75 per hour and we pay them to learn on the job. I would rather invest in myself.
    President:
  • KitchenAid Master
  • 2,651 Answers
When you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Posted on Mar 09, 2008
Kitchen aid torsion spring
I looked up the parts break down for this model there are 7 different ones your last 2 digits are missing this unit dos not use torsion springs the MW door should have a brown arm riveted to the door that goes into the frame this activates a switch
Feb 18, 2015 | KitchenAid Kitchen Aid 30 In. Stainless...
Kitchen aid microwave door error
Try unplugging it to reset. Also, check your circuit breaker...as an additional check point. This will shut power to the outlet as well as the microwave completely.
Mar 05, 2014 | Ovens
I need a user manual for a kitchen aid convection/ microwave oven combo ser # kems307dbs6
Hello & Welcome to FixYa
Please click on this link to download the manual for your Kitchen Aid. Please get back to me if you have any other questions.
Kevin
Dec 26, 2010 | KitchenAid Ovens
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Kitchen aid kemc308kss0 microwave/oven combo
To change a control board, do I need to take the door out?
Jul 28, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Kitchenaid builtin microwave oven # Kemc307KSS
I'm posting this as a solution after I went through several different web sites to and trial & error to fix my "DOOR" error code problem.
The original question I submitted can be summarized: I need to replace the 15A interlock fuse. Can you point me to a manual that describes where this fuse is and how to replace it?
Here's the answer for the KitchenAid KEMC308K series.
1) The service manual is behind the control panel on the left hand side. For my built-in, I turned off the power and removed the oven from the cabinet, exposing the sheet metal shroud. Remove the top piece and there on the left hand side is the service manual.
2) The manual indicates the fuse is in the right rear of the microwave. This is correct, but it is actually accessible through the right side.
As long as I slogged though this, I thought some other people would like to know how to solve the "door" error problem. It could be caused by a faulty control panel, but before going there, the check the switches and fuse in the door interlock circuit. Check this link for a discussion: http://www.gallawa.com/microtech/switch.html
Repair steps:
Remove the rear sheet metal shroud and you see nothing but the back and side of the microwave. Remove the right sheet metal shroud and expose the right side of the microwave. This panel has a bunch of warnings, heed them. However, the are missing one: SHARP EDGES. Think about putting tape on the exposed sheet metal edges. Remove the panel and expose the "guts" of the microwave: Rectifier, wave guide, magnetron, capacitor, and such. The interlock fuse is next to the capacitor contacts. Safely discharge the capacitor (method described in numerous places via google search and the link http://www.gallawa.com/microtech/safety.html ).
After the capacitor is discharged, remove the fuse, verify it is blown using an ohm meter (ceramic fuse - you can't see inside). The fuse is actually (despite what the tech manual says) a 20A 250V fuse. Available at radio shack in a pack of 4 for $2.99. Install the new fuse.
As long as you have this much done, may as well ensure that the microswitches still work. Remove the contacts from the microswitch. There are 2 close to each other. From the 3rd contact to these, one should open when the other should be closed. Ensure that this is true and that when the switch is depressed, the state reverses (the contact that was open is now close & connects to the common). Do this for both door-closed sensing microswitches and replace the wiring to the microswitches. Replace all the microwave side panels and the sheet metal shroud. Turn on the breaker and hopefully, as it was on mine, the "DOOR" error message is gone and it starts up normally.
Oh, when the power comes on the unit runs a self test, lots of blinking lights followed by a power-failure error code when the power comes on. I think it was pf .d=30. Hit cancel and it goes away.
So, this is a pain to do b/c there are about 40 sheet metal screws to deal with and one has to be careful discharging the cap. Pulling the oven out of the cabinet was the hardest part. I build a table at the same height and just slid the entire unit right onto my "work table." If I had to do it again, I'd have the entire thing done in under 30 minutes.
Hope this helps someone else!
sb
Jan 25, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
309 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
