Not spining hi I have a whirlpool 6th sense 7.5kg 1200rpm washing machine that wont do the spin cycle on the front of the control panel the door open light flashes as soon as the problem occurs any suggestion thank clyde
  • zacbear03 Mar 09, 2008
    Thanks Sassybear, switch that locks dooe seems to be ok, will keep trying, thanks for your help
  • 148 Answers
Sounds like the lid switch.
Posted on Mar 09, 2008
My whirlpool 7.5kg 6th sense front loader has stopped 1 min from completing the Mixed Wash cycle. Normally at 1 min it then swings over to 'end' and we can open the door. I have tried turning the power...
Hi Anonymous, is the machine draining out? If not,the pressure switch will not allow the door to unlock to keep from spilling gallons of water on your floor. If that's the case, there's probably something blocking the drain pump. A sock, bunch of lint or even a quarter can block the pump intake. You should be able to access the pump clean out behind the small door at the bottom of the front panel. Get a good wet vac and slowly open the trap and vacuum until no more water is leaking out. If that doesn't solve the problem, it could be a bad door lock assembly, which will need to be replaced. Hope that helps.
Jul 22, 2017 | Whirlpool Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Whirlpool 6th sense washing machine- door light keeps flashing & it will not start the cycle,have to turn off the machine for the door to open .the machine is 4yrs old nxt month.
Hi could be 2 things
Motor brushes worn but at 4 years old unlikely
Or as mine turned out to be dry joints on the controller board just fixed it tonight I also replaaced the brushes on the motor as my machine is 6 years old and were worn
Both jobs are easy thanks hope this helps
Jan 31, 2011 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
Jul 29, 2010 | Whirlpool Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
257 people viewed this question
Top Washing Machines Experts
