Question about Pioneer VSX-D511 Receiver
No Phono setting?
I have a record playing and was trying to hook it up through my component system, but it does not have a Phono setting or at least one that is visable to me. Just wondering if it just dosen't have one :( or if i'm doing something wrong here. I have my record playing hooked into the Aux inputs but i get very letting sound this way...please help
  • dtrain44 Mar 11, 2008
    thanks for the info, its a huge help!!
    D.
  • 1,512 Answers
Hi dtrain
Phono preamps are are considered to be a thing of the past by most main stream manufacturers, so they leave them out of modern amps... supposedly saving some expense in manufacture also. -the i generation mostly dont even know what vinyl is ... poor souls. The good news is you can get decent "bolt on" preamps to listen to your favourite records. It plugs in line with your turntable and aux input on your amp, and generally uses an external power source. you can go to here and get one online starting at around $30 plus delivery.
good luck, happy turntabling:)
regards
Graeme
Posted on Mar 09, 2008
I have a Yamaha RV-V450 receiver. Where can I hook up my turntable. I have tried many different options. I can hear very faintly the record playing but only after turning the volume up. I am having trouble...
Turntables generally do not have a strong enough signal to drive an amplifier. You can check on the back of your turntable and see if it has a switch to change from phono to line level. Most do not, but a few will.
If your turntable does not have this switch, you will need to purchase a phono amplifier to boost the signal to standard line level. You can get these on ebay for around $15.
You connect the turntable to the phono amp input and then connect the phono amp output to any of the inputs on the back of your receiver (aux, cd, etc).
NEW BOZAK Phono Preamp Pre Amp Record Player Vinyl LP Album Amplifier eBay
Dec 30, 2017 | Yamaha Audio Players & Recorders
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
I need to connect to a Marantz SR-19 a record player How do i do it
On the back of the receiver there are connections, usually record player should be hooked up on Phono slot. If Phono is not available, trying using Aux or another slot that isn't being used. After hooking it up, remember the place you hooked it up, turn on the turntable, play a record, then hit the button on the receiver where the turntable is hooked up.
Sep 20, 2010 | Marantz SR-19 Receiver
IPOD hook up to receiver
The problem is the phono hookup, which is not a standard line-level input. Phono is only appropriate for a turntable (record player)
Plug the ipod into any other input, and you'll be all set.
If this helps, be sure to hit the "thumbs up" for me!
Jan 10, 2010 | Denon AVR-3803 Receiver
Very poor sound when i play my record player
What kind of record player? Most modern equipment doesn't have a phono preamp to boost the minute signal produced from the phono cartridge to a Line level so guess what, they don't play phono correctly.
Dec 26, 2009 | Sharp CD-C2900 Shelf System
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
Oct 03, 2008 | Philips HTS-6500/37 System
Unable to to dub from the radio, phono,or cd
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
Aug 15, 2008 | Sony TC-WE305 Single Cassette Deck
Hooking up a turntable to a JVC XM-J50 Via AUX port.
You need a phono pre-amp for magnetic cartridge. This will amplify the magnetic cartridge output from its low level to line level which is required for your amplifier.
This can be bought at most audio-file type distributors and stores. There are different quality levels in these depending on how much you want to pay.
Jerry G.
Jun 10, 2008 | Audio Players & Recorders
Pioneer VSX-D511 Receiver Logo
138 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
