Question about Polaroid A500 Digital Camera
Setting the date and time
I have tried to set my date and time with no success? What do I have to do?
  • lechewal Jul 03, 2008
    when the camara is turned on it displays a specific date and time. changes to that date and time can't be made ther, so it have to be existed the date and time setup can be accessed via the regular menu method to change the date and time. but when the camar is turned off it does not hold the date and time that was set but goes back to the same that and time that is alwasy displayed when it is turned on
  • desertswan May 11, 2010
    I cannot get the date to hold....
Mine has the same problem, but when I set it through the menu it acts glitchy.
Posted on Aug 30, 2008
Exit the menu that comes up about time & date when you turn it on. Then press the menu button, use the left navigation button, then scroll down to date & time, and set it there. For some reason when it comes up the navigation buttons won't let you set the time, but when accessed from the menu, it will.
Posted on Apr 21, 2008
How can I remove automated date & time update?
Hi First try to Restore it by selecting Restore Only from the phone setting.After successful restore setting is done please check the time setting.Good luck
Feb 13, 2012 | Nokia Classic 2330 Cell Phone
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
Can't set the date and time
Hi There,                For your pmp 8308 Missil 8gb Mp4 touch screen. You goto the setting icon touch screen button , then got the time setup and touch that to bring up the date window box screen. In there type in your date you need then touch the icon calendar to goto the time window box screen. Type in your time you need then touch the time clock icon. You should the see  SUCCESS pop upin a small window box. then you are done.
Mar 27, 2009 | Network Computing Devices (NSH800S/A)...
Unable to display Date or time in pictures taken from Canon PowerShot A720 IS
You have to select 'Postcard' for the image size -- on the same menu as L, M1, M2, M3, S, Postcard.
Oct 30, 2008 | Canon PowerShot A720 IS Digital Camera
HOW DO i SET TIME ON A 43-3829 ANS MACHINE???
One thing Radio Shack's answering machine [model number 43-3829], is NOT, is intuitive. But I guess you know that already. ;-)
To set the date and time, perform each of the steps below in quick succession, otherwise the machine will drop you out of the process and you’ll have to start over. You have about five seconds between each step, so try and make a mad dash for the finish line (Steps 4.-5.).
Setting Date and Time on Your Answering Machine:
(To set Day…)
1. Turn the answering machine on and hold down the TIME SET/CHECK/>> button until it beeps twice.
2. Press ANNC/DAY/<< repeatedly until the correct day displays / is indicated.
(To set Hour…)
3. Press REC repeatedly until you reach/hear the correct hour.
(To set Minutes…)
4. Press >|| (PLAY) repeatedly until you hear the correct minute(s).
(To Review/Confirm...)
5. Press TIME SET/CHECK/>> once. The machine will play the time and day you entered.
Note:
To exit/cancel the time- and date-setting mode, press ON/OFF/STOP once.
Hope this helps! If you have additional questions, please let me know and I’ll do my best to help.
Gail
Oct 14, 2008 | Radio Shack (43-3829) Digital Answering...
Doesn't hold the current date when turned off
There is a battery on the motherboard, next to the power supply connector, which may be bad or not connected securely.  That's the first place I'd look, although it should produce other symptoms, especially inability to 'remember' other setting, such as channel memory.
Sep 19, 2007 | Cyberhome DVR 1600 DVD Recorder
Polaroid A500 Digital Camera Logo
285 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
