Dell Inspiron 1521 Notebook Logo
Posted on Mar 14, 2010
Inspiron 1521 won't boot up. fan kicks in then shuts down nothing comes on screen
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1122
Points
9
To fix this all you have to do is if you have a air compressor blow out the dust dont get the air chuck to close to the back, once the dust has been blown out your laptop should load up.. the reason it wont load is a safety thing once dust is out the fan wont over run and there for your laptop should start right up
Overheated now won t start
check if cpu fan is working , remove if any dust is stuck in it , if the fan is having a problem try replacing the fan , add heat sink paste if required
Dell inspiron 1521 has to be shut down manually
there are two settings in the bios that need to be changed....one is the automatic sleep/shutdown and the other is the remote wake-up
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
I think faulty motherboard for Inspiron 1521
try to change your ram maybe it will work
2answers
Laptop screen turns off and keyboard freezes just minutes after i turn it on
Check the power source and make sure the cooling fans are not clogged with dust and lint. Laptops will just shut down if they are over heating or not getting enough power.
My screen is black i havent had any problems new battery and adapter i shut it down woke up and its a black screen and cant see anything its never happened before i have no idea and ive had it for 4 years...
If you laptop appears to boot up and the hard disk LED flashes then the problem could be a back light problem. This could be a faulty inverter or a faulty CCFL lamp. Please click on this link to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Need to reset system password on DELL INSPIRON 1521 laptop. Cannot remember correct password. Any suggestions? Windows doesn't even boot. I just get the white screen with grayed out boxes telling me to...
do some google searching. Most laptops have a jumper that can be shorted on the mainboard to reset the bios password. also, some programs have been written to do it as well. Google is your friend here
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
