Question about Dual XDVD8181 Car Video Player
Radio has no power at all. All wiring is connected properly and all fuses are good. It is a Dual xdvd8181
  • 1 more comment
  • Anonymous Mar 12, 2008
    cant get any power to the unit and all the wiring is all correct
  • brrice09 Nov 10, 2008
    I had the same problem and then i messed around wit5h the wires and i got it to work, but now it doesn't go off even when the car is off and it just drains my car battery.
  • swapnilb91 Feb 01, 2009
    I jump started the car and now my entire audio system is not working. My head unit never turns on and i have no music. I am trying to locate the fuse on the actual head unit but can't. Does anyone know where it is.
  • 4 Answers
The fuse is in the black box tied in to the main power wire,the yellow one. open it up and the fuse is inside. if this has been cut off and your other fuses are fine, the unit did not have proper protection and probably fried from a surge or short cicuit . the fuse on the unit should be a 10 amp mini and no higher.
Posted on Feb 19, 2009
My dual xdvd8181 head unit will not power on. i bought it used and tried the old power wires to positive side of battery and ground to negative side and nothing happens. the in line fuse on the power
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Jan 07, 2013 | Dual XDVD8181 Car Video Player
How to install a bypass ebrake switch for a dual xdvd 8183 car video player
use a toggle switch.connect the brake wire from your radio to one side of the toggle swith and the other side of the toggle switch will be connected to ground.then when your dvd comes on flix the switch for a few seconds and switch it back.your dvd will come on seconds later
Jun 28, 2010 | Dual XDVD8181 Car Video Player
Dual xdvd710
check on the main wiring harness you wil see a black box on the yellow wire. open up the cover. there is a 10 amp mini fuse inside. if it is blown replace the fuse. also check your main radio and accesssory fuses in your fuse box. if no fuses are blown check all wiring connections.
Jan 31, 2009 | Dual XDVD8181 Car Video Player
DUAL XDVD8181
I need the bypass code for a xdvd8181
Nov 02, 2008 | Dual XDVD8181 Car Video Player
Short out fuse
Most of the time there is wire touching somwhere or it is not grounded properly. check all wire and check ground wire if not sure reground in new location
Jul 23, 2008 | Dual XDVD8181 Car Video Player
How to by pass the e brake wire
OK PEOPLE, I HAVE THE DUAL XDVD8181 just installed, you don't need to do any kind of code to get the video to bypass. this is what you have to do
Get a toggle switch, one that flips one way for ON, and the other way for OFF. connect parking brake wire (yellow/blue) to one end of the switch and the other end to the ground of the radio (Black wire) leave the switch in off position, turn on radio and insert dvd, when you get the blue screen, flip switch ON OFF ON wait 5 seconds and video will come on. That it fellas.
Dec 11, 2007 | Dual XDVD8181 Car Video Player
Tuner wont save settings
Hi Matt1983,
You must have Battery + power on both the Yellow wire at all times. To get the Radio to operate, you need power on the red and yellow wire. Battery neg(-) is also imprtant, Besure your Black wire is definitly connected to the frame of the care and you can read voltage from the supply power to the black wire. Sometimes you have to remove paint from the area you connect the Black wire.
Nov 22, 2007 | Dual XDVD8181 Car Video Player
Dual xdvd710
find the memory wire [yellow] and make sure you connect it right if that isnt the problem check fuse box or make sure your remote is not hooked there
Nov 13, 2007 | Dual XDVD8181 Car Video Player
How do i by pass the parking brake no video
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
2. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
Oct 09, 2007 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
216 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
