Open the lid, and give it a short twist, push down and twist, it should come off....it sounds and looks scary, but, it won't break....twist it to the right.
Open the battery cover by sliding the latch toward the center of the camera and flipping the lid up. Holding the other side of the camera, lightly slam the end with the open battery compartment against the cupped palm of your other hand and the battery should slide out a little. Grasp the battery and pull it out the rest of the way.
Remove the battery and let the camera sit for a few minutes. Reinsert the battery and turn the camera on. If the error persists, then consult with a Nikon-authorized service representative.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
No tools required! It simply snaps out. Open the battery door so it's at 90 degrees to the body and unsnap the pins where it pivots in the body. If you look closely, you'll see there is enough clearance for the pivot pins to snap out of its holders.
Nikon told me to remove battery, remove SD card, remove lens and then hold the shutter button down for 30 seconds. If the Also sometimes the contact between the lens and body is not quite perfect and removing and replacing the lens hleps. If not it has a 1 year warranty, return to them with the exact error message (even if the problem is just intermittant) and they can usually find and fix the problem if the above things do not do the trick.
Tonya
What about other modes?
Can your camera still take photographs?
You can Try the following;
Remove the batteries , as also remove the memory card. wait for about 5 minutes. Then install the only the fully charged batteries and restart the camera. Try to use the shutter or Aperture mode, hopefully, you turn it on it and should come back to life.
If not, then it best to show to the nearest Nikon service center..
please do rate this solution and thankss for using FixYa!
