Question about HP OfficeJet 6110 All-In-One InkJet Printer
6110 My machine is ticking, what do I need to do?
  • Santosh Kancharla May 11, 2010
    The issue that you are experiencing might be due to dirty paper feed rollers or might be with the scanner mechanish.
    Please follow the instructions from the below article to get the issue resolved.
    Here is the web document:
    http://h10025.www1.hp.com/ewfrf/wc/gener...
    Just copy and paste the entire link into the Internet browser's address bar and press enter.
    Here are the steps to clean the rollers :
    1)Turn off the all-in-one.
    2)Unplug the power cord from the back.
    3)Remove the rear access door .
    4)Clean the rollers one at a time using a clean cloth that is slightly dampened with clean water (preferably distilled water). Rotate the roller to clean the entire surface.
    5)Verify that the three paper feed rollers on the rear access door are clean and rotate freely.
    6)Reinstall the rear access door and then plug the power cord back in.
    7)Turn the all-in-one back on
    Also clean the carriage rod on which the cartridge carriage moves with a soft lint free cloth.
    This should resolve the issue that you are experiencing with.
    Wish you good luck!!.
    Regards,
    Lawrence
    Genius:
  • 3,587 Answers
Call the printer bomb squad?
sounds like it's clicking when the carriage return is hitting something inside.
Posted on Mar 13, 2008
My phaser 6110 wont turn on after a power-out. every time I try it makes a tik-tik noise constantly untill Iturn it off. Please tell me what to do Thanks
The power supply on the printer has blown.
The machine will need to be repaired by a technician.
Parts will need to be replaced.
Feb 16, 2011 | Xerox Phaser 6110 Laser Printer
Manual for model 6110
go to freemanuals.com They may have yours
Mar 28, 2010 | Sewing Machines
Hp 6110 won't receive faxon single line phone with dsl
Have you tried to use the machine on a normal phone line? A dsl line shouldn't be any different as far as fax machines are concerned.
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
6110 Print Cartridge
There is a handle right below the number keys. Once you lift the top part of the machine the ink cartridges scrolls to the middle of the opening. replace accordingly. The ink cartridge numbers are on the lids so you will know which one goes where.
Mar 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Original document stuck in feeder of HP OfficeJet 6110 All-In-One
ok...this is not that hard...you'll need to open up the top of the machine, and most likely remove some components. Take a look at this link first though Got backup?
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110
Is the ticking sound coming from the right side near the bottom? Or the left side near the top. If it is the right bottom then you're looking at a service station. If it is the left top then a scanner unit. Scanner unit is not available from Hp. You can try dismantling and cleaning all mirrors and lenses (usually doesn't work). If it is the service station, you are probably going need parts that are not availble.
May 01, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
