Question about Refrigerators
Can fridge doors be removed easily
Just purchased GE side by side and find it can't be moved through the hall without removing the doors. Is this a big deal?
I've tried calling the store ALL DAY - Best Buy,and they have yet to answser the phone. I'm about to tear my hair out. Delivery is scheduled for Monday, but if they can't do this, I'll have to cancel the purchase.
  • 1 more comment
  • Anonymous Apr 01, 2008
    HOW DO I DISCONNECT THE WATER LINE TO THE FREEZER DOOR TO REMOVE THE DOOR ?
    WANT TO REMOVE THE DOORS TO MOVE FRIG. HOW DO I DISCONNECT THE WATER LINE GOING INTO THE FREEZER DOOR?
  • Anonymous Jun 06, 2008
    I want
  • 504 Answers
If your unit has ice and water in the door, it IS a big deal. The doors cannot be removed without damage to the wiring that runs throught the door for the ice and water dispenser. You should cancel and order a unit that will fit through your doors.
Posted on Mar 09, 2008
  • Kevin Miller Mar 09, 2008
    Through your hall, I mean.
I have a WESTINGHOUSE WSE7000SF side by side
Yes, they can and there will be a wayer line on the freezer door side that will also need to be disconnscted at the bottom.
Sep 21, 2014 | Refrigerators
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i remove the door from a side by side ge fridge , the bottom spacer has broken in half and the door will not close without lifting it.
Don't need to remove door, just get new piece, then block door up remove hinge and replace, just be sure to keep door closed and lighten it up by removing food from it..
Jan 03, 2010 | GE Refrigerators
Do you know of online instructions to take door off a side-by-side GE Adora refrigerator model no DSS25KSRDSS? The door has built-in conveniences so I need some specific instructions on how to disconnect...
there is a cap on the top hinge-remove it--unplug the wires. then unhook the water line from the front bottom(after turning the water supply off).first unscrew the top hinge with the door shut. open the door and lift it straight up until the water tube is free. then take the bottom hinge off.
Oct 28, 2009 | Refrigerators
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Side by side refrigerator problem GSH25KGRB WW
I have the same problem with my GE fridge.  I inherited the fridge with the purchase of my house.  There is a coil located in the back of of the freezer.  Remove the wire shelves and remove the screws and remove the back panel inside of the freezer.  I can almost guarantee your coil is completely iced.  I just use a hardryer to remove the ice.  I need to perform this once every four weeks.  It's a bummer.
Jan 02, 2009 | GE GSS25LGM Side by Side Refrigerator
GE side by side (purchased 2005; don't know exact model)
Defrost timer issue is my guess. It is generally located behind the rear inside panel in the fridge section. I'm guessing about $150-200 or so to fix it.
Jul 24, 2008 | GE Profile PFS22 33" Artica French Door...
Yesterday I purchased a 22 cubic foot GE side-by-side refrigerator, but I find that they won't be able to bring it in unless the doors are removed. (With the original fridge, which had a bottom freezer,...
Sould not be a problem to remove the door handles. If you look on top of the handle, you will see a large screw. Remove this screw and the handle should come free. Reattach the same way after you move the fridge in place.
Mar 09, 2008 | Refrigerators
Refrigerators Logo
308 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
