i blew the two 40 amp fewses so i bought some and put them in. once i did and hooked the amp to the speakers up i was gettin power to my amp but none to my speakers... i switched chanels still no bumps.. the speakers were making enough noise that if i put my ear in the port hole i could tell that the conection was good but still not bumpin
-   have a similar problem, the only thing is i ain't getting anything out of my speaker. i have good power and good ground. fuses are good and wiring is perfect. when i turn on my head unit the power light on the amp turns on green then goes out right away. thinking my amp took a sh!t but tryin to see if there is another solution. help please!! -   pinoyrome
Feb 24, 2009
-   I have the same problem with my amp. I installed a new stereo into my 00' mitusbishi eclipse, and my speakers have no "bumps" either. I was wondering if you fixed your problem, and if so how?
-   FuzzieWuzzie
hi, I have a citroen synergie 2lt hdi with a webasto cooling system heater and would like to find...
(More)
hi, I have a citroen synergie 2lt hdi with a webasto cooling system heater and would like to find the wiring diagram for it, as its on the blink, checked all fuses but there's nowt in the handbook. cheers.
Can you bridge a sony xm-2200gtx amp, if so what polarity on which channel. Currently pushing two...
(More)
Can you bridge a sony xm-2200gtx amp, if so what polarity on which channel. Currently pushing two speakers. trying to see if i can bridge it and use a singe speaker?
